Tumble dryer 'Smart lamp' pcb
  • notallbad
    • Oct 2012
    • 1190
    This operates the drum lamp on a tumble dryer when the door is opened.
    The lamp does come on but is strobing at a constant rate.
    The triac is Z3M and the uc is a MB95F582K.
    Is it likely the uc is stuck in reset?
    Resistors, diodes and cap C1 all appear ok.
    KN1 connections as follows:
    N.C
    RST
    DBG
    Vcc
    Gnd
    Any ideas please.
    • 31247
    Re: Tumble dryer 'Smart lamp' pcb
    cracked solder joints on atleast one connector there
    • notallbad
      • Oct 2012
      • 1190
      Reflowed joints but fault still persists.
      • R_J
        • Jun 2012
        • 9606
        How did you check the cap? What connects to KN1? does it connect to the main controller board of the dryer? or just the door switch?
        • redwire
          • Dec 2010
          • 3912
          I would also check the large square blue film cap, part of a capacitive dropper for MCU power. Careful it has no discharge resistor, so first use a multimeter to read volts and ensure it has no stray charge.
          Resolder connector pins KN3, KN2 and somebody is resoldering but not using enough heat, in the pics. Just need to keep the iron there for a second or two longer.
          The MCU seems to turn on the triac TR1 for an incandescent 15W lamp. Why does it use an MCU to turn on a light bulb?
          I would expect 5V at zener D5 or Z1 as MCU power.
          • notallbad
            • Oct 2012
            • 1190
            Replaced cap C1.
            KN1 not connected to anything.
            KN3 - Lamp
            KN2 - Door switch 'Live', live and neutral
            My diagram was wrong - had 'N' and 'L' reversed
              • 31247
              you dont understand marketing, if you dont put a chip somewhere you cant write "smart" in the name / product description!
              • notallbad
                • Oct 2012
                • 1190
                Across C1 neg and D5 reading 0.9v
                and
                acrosd C1 neg and Z1 reading 2.6v
                These readings are the same on both boards, I have 2 of them, both faulty with the same symptoms i.e flashing/strobing.
                • R_J
                  • Jun 2012
                  • 9606
                  Can you read the number on U1 ? you may need to clean the top with alcohol to read the number.
                    Both boards are doing the same thing, mmm.
                    The lamp is just a incandescent lamp?
                    What happen if you bypass the TRIAC?
                    Door switch contacts are good and not intermittent?
                    I wonder if the door switch can handle 15W load since the dryer does not need this stupid smart lamp function so the board can be bypassed.
                    You can bypass the board and use the door switch to light up LED bulb instead too.
                    • notallbad
                      • Oct 2012
                      • 1190
                      Originally posted by r_j
                      can you read the number on u1 ? You may need to clean the top with alcohol to read the number.
                      u1 - mb95f582k
                      • notallbad
                        • Oct 2012
                        • 1190
                        I think the problem lies with never or rarely being maintained, as with all the machines I acquire first port of call is giving them a thorough clean inside and out.
                        I always recommend that after EVERY use that the water tray is emptied, the fluff filter cleaned, filter housing and door seal and inner door face wiped and EVERY 3 months that the condenser is flushed through with water / wiped over and its housing cleaned.
                        Following these simple guidelines which never really takes long to do can prolong the life of the machine as well as continuing its efficient operation.
                        To be honest the problem here I believe is due to the lamp cover inside the drum cracking and breaking away which then leads to humidity reaching the Smart lamp board which has no other means of protection other than a plastic housing and of course can also damage the main control board which leads to other problems.
                        • R_J
                          • Jun 2012
                          • 9606
                          Originally posted by notallbad
                          u1 - mb95f582k
                          The ic needs +5 volts on it's VCC pin to operate. There is a small chip cap, C3 check the voltage across it, it goes between pin3 (ground) and pin6 (VCC)
                          • notallbad
                            • Oct 2012
                            • 1190
                            U1 - pin 3 to pin 6 - 2.6v
                            • notallbad
                              • Oct 2012
                              • 1190
                              Thanks, swapped out C4 - 100nf cap on both boards and all working again!
                              Thanks very much.
                              • notallbad
                                • Oct 2012
                                • 1190
                                Well actually, it was a 150nf X2 cap but I only have 100nf but working again.
                                There is a timer function that switches the lamp off after 2 1/2 minutes or 15 secs after the door is closed, now isn't that 'Smart'!
                                  Where the heck is C4?
                                  https://www.badcaps.net/forum/attach...1&d=1571056408
                                  https://www.badcaps.net/forum/attach...2&d=1571056408
                                  • R_J
                                    • Jun 2012
                                    • 9606
                                    Good to here its working, C4 is used to isolate and couple the a/c to the D1/D2 diodes, C1 is the filter and Z1 should be the regulator for 5 volts that supplies the voltage for the ic, I suspect the voltage across pins 3 & 6 is closer to 5v now.
                                      It is kind of bad to have the replacement board with bad cap already.
                                      • redwire
                                        • Dec 2010
                                        • 3912
                                        Glad it's working, these appliance boards can be priced crazy high.
                                        Can you post the dryer model number or board p/n for others who might end up here.
                                        I see more and more film capacitors failing in capacitive dropper use. It seems to be the metalization is cracking and flaking inside. Epcos parts are not lasting.
                                        • notallbad
                                          Heat pump tumble dryer regas
                                          by notallbad
                                          Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                                          The dryer currently in question runs on R134a.
                                          The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                                          I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                                          07-16-2023, 01:27 PM
                                        • Petros_Z
                                          candy tumble dryer (evoc 981 at-s) Component 738
                                          by Petros_Z
                                          Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
                                          It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
                                          Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and...
                                          01-04-2025, 02:17 AM
                                        • spleenharvester
                                          Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
                                          by spleenharvester
                                          This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
                                          Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
                                          Cheers
                                          12-16-2024, 03:36 PM
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
