Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
This topic has been answered.
  • spleenharvester
    • Mar 2010
    • 993
    This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
    Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • Answer selected by spleenharvester at 12-17-2024, 04:41 PM.
    stj
    • 32068
    no leakage,
    tumble dryer elements are just springs mounted through mica spacers.
    they arent encased.
    • petehall347
      • Jan 2015
      • 4480
      clean filters and anything else that should be cleaned
        • 32068
        check the airflow path to make sure nothing has come unsealed allowing damp air into the main body of the machine
        • spleenharvester
          • Mar 2010
          • 993
          Thanks both, will double check
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8887
            Check the heating element for leakage. You need a insulation tester for that.
              • 32068
              no leakage,
              they arent encased.
              • petehall347
                • Jan 2015
                • 4480
                there might be a problem with the sensor causing it to stop early .wouldnt cause the tripping though . what's really needed is a ma clamp meter to check leakage . rcd tripping could be something else on that circuit . what ma is the rcd ?
                • spleenharvester
                  • Mar 2010
                  • 993
                  Pulled it apart today, the load bearing(!) mica at the far end had collapsed under the weight of the spring. Bit disconcerting to know 1600W of heating element is held in place by mica paper, not to mention that it costs £65 for a replacement, but hey ho.
                    • 32068
                    i'm not sure that explains the RCD tripping though.
                    not unless the spring dropped onto the body of the dryer.
                    • spleenharvester
                      • Mar 2010
                      • 993
                      Yeah I'm not sure why it would trip the RCD either actually, I don't see any way it could have made contact other than arcing perhaps.
                      I am going to replace it anyway on the basis that it has literally imploded, but I suppose if it doesn't fix it the next suspect will be the PCB? There's no mains filter on this model, at least not a discrete one, so I assume it is mounted onto the mainboard somewhere. Might lift it out and have a close look.
                      E: Just lifted the board out. Part number 2982740900, which returns absolutely no results on google at all. I don't see anything untoward, a few shitty solder joints but nothing that should be tripping an RCD.
                      • spleenharvester
                        • Mar 2010
                        • 993
                        Replaced the element today, done three cycles and touch wood haven't had any cutting out or nuisance tripping.
                        • spleenharvester
                          • Mar 2010
                          • 993
                          Spoke too soon, after a few weeks of working fine it's cutting out again, it seems to be losing power very briefly as I am finding it just sat there with the mode select LED lit, and it starts again as soon as the start button is pressed no problem... not sure what else to try at this point other than just replacing the mainboard
                          • petehall347
                            • Jan 2015
                            • 4480
                            could it be the house power sometimes dropping ? i get this from time to time and notice i have to reset my battery chargers
                              • 32068
                              thats unlikely, but i wonder if it has a capacitive dropper psu.
                              • spleenharvester
                                • Mar 2010
                                • 993
                                Fault with the wiring is possible as it's a bit of a mess, but the washing machine is running fine and that's on the same radial.
                                There's no interference filter on this machine either, the only bit of AC to DC circuitry I can find is here. I am wondering if maybe that small transformer has a problem with its windings, but since it is probably a custom wind I imagine I'll have to replace the whole board
                                Click image for larger version  Name:	QOsBVof.png Views:	0 Size:	466.6 KB ID:	3549215
                                If the fault isn't the board then pretty much the only electrical part I haven't ruled out is the motor I think
                                  • 32068
                                  a recap wouldnt cost much - use decent ones
                                  maybe it's marginal and the psu is glitching
                                    • 32068
                                    just to clarify,
                                    the device is resetting itself, your not tripping an RCD anymore?
                                    • petehall347
                                      • Jan 2015
                                      • 4480
                                      when it cuts out are the clothes still wet ?
                                      • spleenharvester
                                        • Mar 2010
                                        • 993
                                        Yes haven't had any RCD trips since replacing the element, I haven't seen the exact moment it does it but it seems to just be resetting.
                                        Clothes are wet and steam coming off when it stops
                                        • petehall347
                                          • Jan 2015
                                          • 4480
                                          any error codes displayed ?
                                          • LEEDASH
                                            Creda 37760 Tumble dryer capacitor
                                            by LEEDASH
                                            Hello all I have a creda 37760 tumble dryer I'm trying to seek a replacement capacitor the size is 7.5 with three spade terminals I've seen four spade replacements online which state universal can these be used
                                            08-30-2026, 07:28 AM
                                          • notallbad
                                            Heat pump tumble dryer regas
                                            by notallbad
                                            Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                                            The dryer currently in question runs on R134a.
                                            The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                                            I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                                            07-16-2023, 01:27 PM
                                          • Petros_Z
                                            candy tumble dryer (evoc 981 at-s) Component 738
                                            by Petros_Z
                                            Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
                                            It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
                                            Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and...
                                            01-04-2025, 02:17 AM
                                          • tmcw
                                            Tumble Dryer - motor start capacitor
                                            by tmcw
                                            I was looking for a replacement capacitor for a tumble dryer, and I found one on eBay that has the correct values, and even looked similar, but of course, when the capacitor arrived, it didn't look like the cap in the listing picture.
                                            I've attached the old (left) and the replacement (right) caps in a picture. The new one has plastic housing, the old one has a metal housing and is bigger. Am I likely to have any issues with this replacement?
                                            Thanks....
                                            05-09-2022, 09:11 AM
                                          • notallbad
                                            Indesit vented tumble dryer control board dead
                                            by notallbad
                                            Anyone able to help diagnose the fault with this board please.
                                            Hopefully photos are clear enough to give me direction on what readings to take and where.
                                            All ancillary components of the dryer have been tested and work i.e heating element, thermostats, sensors, motor, door switch, wiring harness.
                                            So theres 230v at the control board but no life whatsoever with or without the ancillaries connected.
                                            The on/off/timer dial contacts are clean and make good contact. All the through hole mounted components appear to be good i.e diodes, resistors,...
                                            01-04-2023, 05:49 AM
