Anyone repair appliances? GE ice maker issue
  • caphair
    • Nov 2011
    • 1249
    Ice maker in my GE Model# GDSOKCXARWW bottom freezer stopped working.
    I've diagnosed no 115acv reaching the ice maker itself but can't figure out where it would come from.
    Would it be from the main board itself or is there another line with a fuse possibly?
    The ice release mechanism was jammed and I'm guessing it overworked the motor causing something to either burn out or a fuse/relay to pop down the line preventing power reaching the ice module. I've jumped 115acv directly from a receptacle to the ice maker and it powers on so it's something with the feed.
    Any help would be appreciated
  • redwire
    • 3900
    Re: Anyone repair appliances? GE ice maker issue
    I can't find that model number. or post a pic.
    Most GE/Whirlpool/Frigidaire have a heater that warms up the mold so the motor can then eject the ice. The mold would have a thermal fuse (in contact with the mold). These pop if the harvest cycle jams and the heater stays on. Other posts say the thermal fuse is in-line in the wiring harness.
    GE icemaker kit (one style)
    • caphair
      • Nov 2011
      • 1249
      But with the ice maker removed I don’t get 115acv at the connector that the ice maker plugs into. I only measure 15acv. I’ve uploaded pics to original post
      • redwire
        • 3900
        Icemaker power is in series with the (freezer) door switch, so push it in and see what you get.
        • caphair
          • Nov 2011
          • 1249
          Ah thanks for that yes now I have proper voltage. So the heater fuse should be inside the ice maker itself then?
          https://www.geapplianceparts.com/sto...y/GDSC0KCXARWW
          • caphair
            • Nov 2011
            • 1249
            Is the thermal fuse accessible?
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              The two ROUND, black spots (one above the other) to the right in your first photo represent the leads that feed the heater. Check for an open. Trace the pigtails to see what they tie to.
              Note that the small "timing motor" will have a cam driven switch on it to apply power at the right point in the "mechanical" cycle. So, if you have continuity IN the heating element, next verify that the switch engages the power to that element (and hasn't worn itself open).
              You can often diagnose these on a bench just (patiently) waiting for a complete mechanical cycle and noting where it stalls.
                • 30937
                i see it's got the infamous film caps on it - check them for cracks or splits.
                • redwire
                  • 3900
                  It seems to be a GE IM6.
                  Follow red wire PCB label "TCO" to the TCO fuse then heater, check ohms-- it only goes to the heater, so the motor should still run.
                  I usually find the thermistor gets knocked out of place on Samsung icemakers.
                  Diagnostic mode
                  "...If the Harvest state takes more than 7 minutes, the icemaker will initiate a Harvest Fix mode. In Harvest Fix Mode, if the Harvest state is not complete within 30 minutes, the icemaker will enter the Fault state. In the Fault state, the green light will flash. This often indicates the icemaker will need to be replaced."
                  Good to know the Lelon electrolytic works when cold lol
                    https://www.badcaps.net/forum/attach...0&d=1533664557
                    You can see that red wire which is connected to the 'T.C.O' terminal of the PCB goes to one end of the fuse, anther end of the fuse connected to the black wire of the heater unit.
                    • caphair
                      • Nov 2011
                      • 1249
                      Ok so the thermal fuse seems fine tests good in continuity mode.
                      I’m hoping the ice release mechanism begins jammed was the only issue. It has power now as indicated by the green light when I close the door switch.
                      I can hear water being entered just have to wait I suppose to see if it produces ice
                      • caphair
                        • Nov 2011
                        • 1249
                        How long before it starts producing ice? If it’s going to work
                        • CapLeaker
                          Leaking Member
                          • 7992
                          that takes a few hours to do so... let her rip over night. If you got ice, its good!
                            • 30937
                            with those caps, the more interesting question is: how long before your engulfed in smoke!
                            specially in a damp enviroment!!
                            • caphair
                              • Nov 2011
                              • 1249
                              Are they prone to failure?
                                • Jul 2011
                                • 6024
                                Yes when I see this no name brand I replace them on site
                                • redwire
                                  • 3900
                                  Rifa/Kemet (PME271) capacitors fail in X-cap (across the line) applications.
                                  I'm not sure why - if it's the epoxy or paper dielectric that shorts with age, or if it's due to mains transients the caps can't handle. I see many with the clear epoxy cracked.
                                  Your icemaker PCB I see three of 2.2nF X2 275VAC, for snubber use.
                                  If they are Rifa and one is an X-cap, I would replace them.
                                  Wurth makes some low cost ones.
                                    • 30937
                                    what happens is the resin shrinks with age and cracks.
                                    then moisture gets into the foil wrap and shorts it out.
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      Good to know. Are they cheap to use? Curious why they're used especially in a moisture prone area like a freezer.
                                      Also glad to report it's making ice again
                                        • 30937
                                        panasonic make cheap replacements.
                                        the problem is the clear epoxy - they may not have realised at the time that it will slowly shrink.
                                        it was a good idea in a way, use clear epoxy and you dont need an outer plastic box = saving money.
                                        maybe they didnt plan for what happens 10 or even 20 or 30 years later.
                                        the real problem, is they where considered the best, and are in a LOT of high end kit.
                                        inc a lot of test gear.
                                        and they are INSIDE a lot of those metal line-filters with the IEC socket built in.
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          Today, 01:10 AM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
                                        • wizard13
                                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                          by wizard13
                                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                          • Part Number (P/N): PYU13E-00C00PFR
                                          • Serial Number (S/N): 22028896H
                                          • System Configuration (SC): A1PYU13E1127
                                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                          • Power Input: DC 19V –
                                          02-28-2025, 02:43 AM
