Bosch dishwasher motor relay
  • notallbad
    • Oct 2012
    • 1190
    Found the circulation motor pump relay stuck in its normal state so replaced it with a spare from my parts drawer.
    Is the blue relay a suitable replacement?
    What possible problems could have been caused by the relay being stuck in its normal state, in this instance normal state is running the motor via the 8uF starter cap.
    Does the illustration on the white relay indicate its normal state i.e when not energised
    • 31061
    Re: Bosch dishwasher motor relay
    i think the blue one is better.
    try it - nothing to lose.
    • notallbad
      • Oct 2012
      • 1190
      its already fitted but the motor is still not pumping fast enough to create enough pressure to turn the spray arms. the water alternates between top and lower arms but pressure is low to non-existant. can hear the water divertor running too and can confirm the mechanism is turning! the water pressure switch in the heating element casing does engage/operate
      i think the motor windings are shorted.
      at the motor cap i initially get 440v which then drops to 180v after the motor pump has started and the relay has kicked in switching over to 240v supply. i think thats whats happening!
      also replaced the cap, no change.
        • 31061
        have you checked there is no restriction or blockage in any pipes?
        the other thing to check is the pump - does the rotor spin freely??
        • notallbad
          • Oct 2012
          • 1190
          the blade doesnt feel loose and turns freely, both shaft and blade turns and seems to be on there tight.
          have checked pipes for blockages i.e inlet hoses, drain hose and filling chamber/matrix but not yet inspected heating chamber or divertor assembly, the tub comes off completely on this model to gain proper access, bit of a pain.
          • notallbad
            • Oct 2012
            • 1190
            I think stripping it down is the only way to be sure but having had another look at the motor, limited access whilst assembled, it would seem the impellor is in 2 halfs.
              • 31061
              why not test it "stand alone" with a bucket of water and some lengths of pipe?
              • notallbad
                • Oct 2012
                • 1190
                well it would seem the impellor is in 2 halfs. the impellor half has separated from the screw on rotor plate ( one half is blue and the other white, the blue impellor half has little lugs that locks into holes on the rotor plate, the lugs have worn down and no longer stays on the rotor plate properly)
                it was kind of 'locked' into position but obviously when the motor spins up it was throwing the impellor off the rotor plate and possibly only sometimes locking into position
                as a temporary measure I have glued the impellor to the rotor plate, blobs of glue on the lugs, put back together and hey presto, pressure back and spray arms rotating again!
                replacement recirculation motor seal kit incl the impellor is £43 incl postage, (if that one fits my model) so that might be a good investment but will have to strip it completely down again, no leaks yet which is common when reassembling.
                its a 15 yr old machine and the only problem we have had with it is the water matrix in the drain pipeways was gunged up around the pressure release valve but thats common on all machines with this design, or at least that I have seen so far, machines I have repaired in the past that is.
                oh yes and then there was the recall repair but that was not an issue, done for free and before it caused a problem.
                come to think of it, I may have replaced the heating element and replace a divertor plate from a tattt machine that had no resale value so parts used as spares at the tine.
                WELL DONE BOSCH!!!!
                Wont be spending £400 on a new one just before xmas, a big relief. i also wonder if bosch are still built as good. got this one for £310 in feb 2003 (i did get a £50 discount) so doin well and in pretty good condition externally still. not saying goodbye to her just yet.
                  • 31061
                  are these "lugs" on the edge, or more inward?
                  maybe you can drill them out and put metal in instead - like grubscrews for example.
                  • notallbad
                    • Oct 2012
                    • 1190
                    i did consider that but happy to settle for the glue for now, not sure if or how long it will last especially with hot water but may consider that if it fails again.
                    the lugs, theres about 14 of them, are actually on the fins so might not be possible
                    this is the only photo i took, stoopid me, should know better!
                      • 31061
                      it almost looks like an epoxy, like it had the fins held in it while it cured!!
                      • edugimeno
                        Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                        by edugimeno
                        Hi everyone!
                        I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                        I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                        This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                        To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                        I respected the polarity, positive to cathode of protecting diode
                        So provided all...
                        04-18-2024, 01:15 PM
                      • I8jjrnhh4thvtl0dWZoY
                        Repair Manual for Bosch SHX55M05UC/46 Dishwasher (702_58300000148618_ara_en_a)
                        by I8jjrnhh4thvtl0dWZoY
                        Repair manual part number 702_58300000148618_ara_en_a
                        It took way too much effort to find this manual so I am sharing it here so the next person can find it easily. Also, I am mad at Bosch for not publishing it on their website, so they deserve to have it leaked....
                        07-14-2025, 07:36 PM
                      • valvashon
                        Repair Success! Middle Atlantic UPS2200R-IP
                        by valvashon
                        Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                        Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                        02-06-2024, 12:54 PM
                      • juergenb
                        Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                        by juergenb
                        i am asking for some Help.
                        I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                        The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                        So i got a few of these from Banggood.
                        I swapped the motor and now i have a new fault condition.
                        In a working Frother you would press the start button, it will light red and work for a few minutes.
                        If you press longer it will light blue and just mixup the milk.
                        With the new Motor it just starts...
                        03-23-2021, 11:24 AM
                      • sbt123
                        charnwood w821 mini wood lathe motor problem
                        by sbt123
                        hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                        10-27-2024, 03:43 AM
