Re: Jet AFS-1000B Air Cleaner
What parts are under the big heat sink
Whilst not a legal requirement, ensuring all devices are PAT tested have been a requirement for insurance in several places I've worked. Both the device and flex are tested.
That air cleaner is a portable device. It's got a carrying handle on the top.Leave a comment:
you shouldnt pat-test electronics, the input stage often isnt rated for more than 400v
you dont need to anyway, firstly there is no legal requirement to pat-test anything - it's a scam-industry.
second, it's only for portable devices - hence the name "portable appliance test" and is targetted at the flex and it's entry into the device more than anything.
i look forward to someone trying to rebutt this so i can post a link to the government website!!
My JET AFS-500B (looks like the same board as the 1000B) was making grumbling noises on startup and not really getting up to speed so initially I assumed that the bearings in the fan had dried up (it's about 16 years old), but on giving the rotor a spin by hand it ran for ages with no mechanical noise, so I had a search and arrived here.
I've been familiar with ESR problems for many years - when I first fixed power supplies with high ESR capacitors it was just like magic! I had a Bob Parker ESR meter and more recently have been using a Peak Atlas ESR70 ESR meter.
So, took the board out and firstly visually checked the Cs (C1 and C3) for cracks bulges etc. All looked OK so tested their ESR: C1 0.94uF/0.60 ohms, and C3 590.4uF/0.16 ohms. Not what I was expecting, ie they measured OK!
Powered up the board and found 2.6V across C3, where I'd be expecting something like 5V or so, with a 5V6 zener close by. Despite the low volts across C3 the board seemed to work fine; the control buttons did what they were expected to do and so did the LEDs. However this was without the motor connected, as it was still in the cabinet mounted high in the workshop.
So, long story short, the actual problem was the two-pin connector for the AC-in, marked AC1 and AC2. While gently flexing the components and looking at the solder side I noticed that the connector had been soldered in without the pins being square to the board, so the tips of the pins were only attached to the board with a thin film of solder, and when wiggled a bit the solder broke away.
I desoldered the connector, cleaned the pads etc and resoldered it correctly. This now gave me 5.2VDC across C3 so I confidently got up the ladders again to refit it to the cabinet. PAT tested it (don't forget the earth wire from the earth stud to the motor). Powered it up and...
All sorted!Leave a comment:
c2 being marginal could do this too.
motor drops the line voltage slightly and micro resets.
measuring across c3 while starting the fan may reveal this.
or just replace c2 and c3.Leave a comment:
Thanks for all this information on this forum! My neighbor also has the JET and he recently (Nov 2017) tried to fix it by replacing the board (for $80) that he bought around 2015. Unfortunately, he didn't screw down the board (just wanted to see quickly if it worked) and the fan sucked it towards metal and the sparks did fly! The board is really messed up; blew some PC runs, fried some resistors, and blew apart (like into 2 pieces) one of the Triacs.
Anyhow, I have this 'fried' board Rev 1.1 and the original defective board Rev 1.0 and I think given this info that I can get one of them to work; I'm focusing on the original board since it is intact. I replaced all 3 Triacs on the Rev 1.0 board (they really aren't very expensive, like under $1 each, and upgrade from 400v to 600v) and suspect the 2200uf 10v 'slightly bulging' capacitor so it will get replaced as well. (I did unsolder the capacitor and it seemed to be ok, but I'll replace just to be sure.) I'll check the board out carefully at the bench to be sure the power supply and IC is working before putting it back into service. The photo of the old board is exactly like Elmo's post above.
I noticed that his new board is REV:1.1 and they made some changes. The Triacs were changed to 600v, not sure if this was because you can't get 400v anymore or for some other reason. Also instead of 2x BTA08 they went to one BT137-600E (for M pin) and one BTA08-600C (for L pin). BT139X-600F still used for the S pin. Also there are circuit changes that I have not traced out. They also changed the IC to an 18 pin device "SN8P2612PB 145CATD11", and they added some resistors and capacitors too.
As I'm focusing on the old board, I probably won't work on this one Rev 1.1 unless I can't get the old one working again, for example if the IC is dead.
Again, thanks for the input from this board - very helpful!Leave a comment:
I didn't record the voltage. I think it was a little over 5 volts. However, the ripple was substantially more - about 60 mV. Both times the voltage was measured with the control board out of the air cleaner, i.e. no load on the triac.Leave a comment:
Thanks for the follow-up on the repair.
BTW, what DCV did you get before you changed the C3?Leave a comment:
Success! I replaced C3 and am now getting 5.1 VDC with about 5 mV of ripple. I seems our forum is well named. Bad capacitors have been the cause of two of my electronics problems and probably more. I have now run the air cleaner for over an hour without shutting down. Thanks to everyone for all their thoughts, effort, and advice.Leave a comment:
half a triac equals a diode.Since triacs are used in AC circuits, I can't see how a bad one would impose a DC component to the load. If the triac becomes shorted, your motor runs all the time. If the triac has turned into a resistor, then the motor gets lower AC voltage than it is used to. The motor might not start or may get hot, but the triac will get even hotter. So far, no evidence of thermal problems. The controller would be the next best choice.Leave a comment:
Other possibilities, taking into consideration all of your observations: the 32 KHz clock crystal used in this circuit is a type widely used in lots of gear. If possible, check the waveform on the osc pins, or if test equipment is unavailable replace it next time you place a parts order (they are very easy to find and inexpensive). Also check the resistor on pin 2 of the controller. This resistor sends zero crossing information to the controller, and it may have changed value. That would upset the firing on the triacs.
As mentioned before, the soldering on your board is terrible. Heat and vibration will create miniature cracks that can hardly be seen. I would run small tinned bus wire along any of the AC traces starting with the board AC connector pins. The points where the connector pins solder to their traces are of special interest. Same goes for the legs of the triacs.Leave a comment:
Thank you all for your suggestions. I can't see the motor, but I presume that is the correct one since it is the replacement part for the AFS-1000B. I think the motor is all right since I ran it for over an hour with the board jumpered out. I just measured the -5V power supply voltage. It does indeed measure 5 volts with about 60 mV of ripple. Of course this is with no load on the board. This may not be surprising since the blower always ran when started. It just does not run for long when powered by the board. I, too, am suspicious of C3 since the top of it is bulged out somewhat. I guess the only thing to do is to replace it and see if that helps. It seems that most of you think Panasonic makes good capacitors but are not Nichicon, Rubycon, Kemet,ans Vishay good brands too?Leave a comment:
That's a multispeed PSC motor- exactly the same as a common furnace blower motor. Four wires=three speed taps, plus neutral/common.
If more than one tap is energized at the same time, you get smoke and a dead motor.Leave a comment:
Is this the blower motor?
http://www.ereplacementparts.com/motor-p-446851.html
It has AC caps for the motor.Last edited by budm; 03-04-2016, 05:56 PM.Leave a comment:
the original soldering is a joke, most of it is only touching the pins and not binding to them.
it almost looks like they used the wrong type of flux on the production line.
specially the large connector.Leave a comment:
If C3 is bad/fake/questionable, the micro gets bad power and resets- unit appears to then be "off," since powerup state for micro is to default to fan off.
This is a capacitive divider power supply- C2, 2.2u (10%) if decreased in value will cause strange symptoms- things like micro dropping out upon driving triac gates (for instance).
I'm suspecting C3- replace with good 105 degree low esr unit, such as for an SMPS. Extreme ripple into that micro will wipe its programming, seen this with cheep "tower" fans and crock pots. Use PW, HE, FR, FC, or equivalent.Last edited by kaboom; 03-03-2016, 07:24 PM.Leave a comment:
by piipoHi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much1 Photo
09-18-2024, 01:55 AM -
by hemant_2222Hello Everyone,
Hope everyone is enjoying their repairs at hand!.
I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
Please refer to the attached picture, i think the voltage divider is missing...-
by dfearI have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
It came in for a power issue which I have finally resolved by replacing the power supply.
The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
Anyone have a clue how to fix TV?
FYI: I have checked the remote work s by pointing it at my camera on my phone.... -
by wolf1976hi i have a receiver that is destroyed from the overvoltage i guess
my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
the motor fan has not label
i have an other receiver operational
In your opinion can i measure the voltage at the output ?
what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
thanks in advance... -
by t4796I managed to drop this recently. It fell flat and square onto the floor from about 1.8m. Can't remember if face up or face down.
The remote still kinda works but the display is blank and only shows up if I repeatedly flick the little silver crystal/oscillator looking thing on the board.
Not sure if this part is the culprit or if flicking it is moving something else, but it seems localised to that component as far as I can tell.
Having trouble working out the value of it since it doesn't seem to have anything other than a brand name printed on the side of it.... - Loading...
