Hotpoint FFA47X Fridge Freezer
  • Rhothgar
    replied
    Re: Hotpoint FFA47X Fridge Freezer
    Gutted.
    Have done the triacs and a tinned six strand wire and the display is still dead!
    Do I spend more time on it or buy a new fridge? Problem is it's a big fridge and it would be top end of £700 for same storage size and...
    I hate being defeated!
    Addition Information: I think the triacs are properly soldered in. I found another capacitor which had blown obviously during the voltage surge which blew the triacs and I have found some resistors which although I haven't checked resistance bands yet they appear not to be giving ANY reading in circuit whilst others are. Obviously need to work out their rating, desolder one leg and check them again but it seems suspect with no reading whatsoever.
  • Rhothgar
    replied
    Originally posted by stj
    unless you want 25meters of it, i wouldnt get wire from RS
    Good point. Tinning is the answer then albeit I didn't want to strip the insulation off a multi strand.
    Lesson learned from blowing the triacs up though as made me cautious. Referring back to the PCB pictures, will it matter what diameter the wire is because when I used the thick copper single strand as a jumper across the evaporator defrost terminals that is what blew the PCB to smithereens!
    replied
  • Rhothgar
    replied
    NO
    anyway, how would you solder it?
    strip some stranded wire, twist it and tin it
    Might try that stj.
    I am nipping into local RS Components tomorrow to pick up triacs. What should I be asking for if I want something like this off the shelf?
    replied
    NO
  • Rhothgar
    replied
    solid will be better for keeping shape.
    Could I use a strand of solder? It's unlikely to reach high enough temp to melt!
    replied
  • Rhothgar
    replied
    i imagine it uses the flow from the fan across the coil to stop it melting down.
    Thanks for clarifying.
    Problem is you remember I vapourised the main board? Well. The fan isn't turning.
    Once I repair board this week, I can then start diagnosis of other components.
    Someone kindly suggest I use a jumper wire for bridging the points on the vapourised copper track.
    Will any copper wire do with insulation? Like a multi strand wire say 1.0mm diameter?
    replied
    no polarity, it's an ac fan.
    it will get hot, look at the design.
    you have a constantly powered coil on a core that goes around the motor shaft.
  • Rhothgar
    replied
    you can hook it to the mains for a test - watch your fingers with mains fans as they have high-torque.
    Noted. But does it matter which way? That is my concern. I cannot afford to buy a replacement if I damage it. Chances are it's burnt out anyway because it felt so hot but...
    replied
  • Rhothgar
    replied
    Sorry. It is 220-240V
    I do have a photo.
    replied
    have you got any foto's of the fan?
    does the label state the voltage?
  • Rhothgar
    replied
    Finally I have the service manual arriving for this tomorrow.
    I have sourced the triacs and will be ready to resurrect this hopefully this week before the missus gets back off holiday.
    Quick question. I took one of the fans out last night and it was too hot to touch. I had switched the unit on earlier in the day as the evaporator is still working and the freezer gets cold.
    The fan has two wires and is a type F64-10 with MES Swiss made on it.
    Is it safe to simply connect it to a live and neutral to see if the fan spins and would it matter, for testing purposes, which way the live and neutral are?
    Presumably it will just run backwards?
  • Rhothgar
    replied
    so the cpu controls the internal lights?
    or does it just give a short boost to make up for the door being open?
    I'll pass on that as I have no idea.
    Maybe the reed switch is there to communicate with the EEPROM when the door has been open for 2 minutes and to set the beeper off to alert the user to door being open.
    replied
  • Rhothgar
    replied
    i wonder why it has a reed-switch?
    I have a manual for another Hotpoint with a similar-ish layout in front of me. Just 'reeding' through it. Excuse the pun!
    It is located such that a magnet in the fridge door closes the reed switch when closed.
    replied
    When you have a controller board on any type machine the worst thing you can do is apply power other than the power in to the board unless you know what it powering
    Most of the time when you want to see if a part works or not unplug what you want to test
    replied
    Originally posted by Rhothgar
    Thanks stj.
    I'll get some ordered in. Bet I can't buy singles though.
    It is now because when I used a jumper wire across the defrost gutter resistor terminals, it blew the main board.
    What I can't understand though is if a wire is in there simply to heat up and keep ice at bay using a certain resistance, why would another wire blow the PCB? It conducts!
    I have obviously have a lot to learn and some things I will never understand.
    Does everyone on here get the feeling I shouldn't mess with electrics?
    My missus is moaning now that I am trying to fix it!!!
    the heater wire has a high resistance an draws less current than your copper jump.
    if you wanted to see if it was getting power, you should connect a neon with inline resistor to the terminals.
    you can scavange those from old kettles, boiler switches ec.
  • clearchris
    replied
    Sounds to me like you put some high voltage where it didnt belong. Yes, things conduct, but all things will burn if they are made to take too much current.
    Also, if you jumped across where the heaters plug in, well, that circuit needs a load (the heatoror the current shoots way high and you see what happened. What you did is create a short, a path of low resistance that is not able to carry a higher current without burning.
    Can anyone explain that better?
  • CG2
    Liebherr Fridge Freezer KGT 3456 not working
    by CG2
    To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
    01-25-2023, 02:12 PM
  • mikey5791
    Help repair Panasonic fridge not cooling
    by mikey5791
    Hi all forum members,
    Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
    After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
    07-16-2025, 02:01 AM
  • tmcw
    Fridge - Gram
    by tmcw
    Have this fridge, laboratory grade unit, not working fully.
    It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
    The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
    10-10-2023, 05:00 AM
  • unimatrix93
    Replacement transformer for Samsung fridge
    by unimatrix93
    Dear forum
    My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
    No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
    The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
    My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
    07-14-2025, 02:16 AM
  • lapfix
    Dell latitude 5320 South peak 13 not power on.
    by lapfix
    Hello friends
    Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
    motherboard south peak 13 mb 213252-1
    i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
    i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
    As i undestand from many topic here ,...
    04-29-2025, 06:22 AM
