Whirlpool dryer control board
  • Eaglecrest
    • Jul 2018
    • 163
    OK, so I resoldered the board and also got a second, used board, that supposedly was tested to be OK. With neither board does the control panel come on. The light in the drum is one so it is getting some power. Any thoughts as to where to go next? If this isn't a good source for support can anyone suggest a better source for support?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5401
      • New Zealand
      • Electronics and computer repair
      I may have missed it but I didn't see anywhere where you actually tested the relay to see if it still works and that the contacts are not burnt or gone high-resistance.
      If the burnt trace was caused by burnt contacts in the relay, leading to excess heating of the contacts, and thus burning of the PCB as well, then you still have a problem.
      Heating the relay to soldering temperature while doing the trace repair may have finished the relay off, if it was already damaged.
      -David VanHorn
      • R_J
        • Jun 2012
        • 9775
        • Making Money
        Does the drum lamp go out when you close the door? check for 120vac on T1 transformer primary (you can check across V1 mov), Do you have any DC voltage across the large capacitor CG0? (The cap near BZ1)
        If neither board works, then there is likely something else wrong in the wiring, broken wire, bad plug etc.
        • hartleyhare5
          Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
          by hartleyhare5
          Post body:
          I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
          Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
          03-26-2026, 03:47 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • mgourgios
          Whirlpool S20D TSS33-A/G no defrost
          by mgourgios
          I am trying to repair this refrigerator and I have reached the point where I suspect the main control board / defrost logic, but I would really appreciate another pair of eyes before replacing the board.
          Whirlpool S20D TSS33-A/G⏎
          Service No.: 858615701012⏎
          Main PCB: ITW Ispracontrols MB700000G / 461950248993A⏎
          Controller: Microchip PIC16F877-04/P
          The original fault started with problems around the compressor. The compressor relay (RT114005) was mechanically damaged and was replaced with an equivalent one (OMRON G2RL-1-E). I also replaced the...
          10-14-2026, 03:01 PM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
