Whirlpool dryer control board
  • R_J
    replied
    Originally posted by Eaglecrest
    OK, so I resoldered the board and also got a second, used board, that supposedly was tested to be OK. With neither board does the control panel come on. The light in the drum is one so it is getting some power. Any thoughts as to where to go next? If this isn't a good source for support can anyone suggest a better source for support?
    Does the drum lamp go out when you close the door? check for 120vac on T1 transformer primary (you can check across V1 mov), Do you have any DC voltage across the large capacitor CG0? (The cap near BZ1)
    If neither board works, then there is likely something else wrong in the wiring, broken wire, bad plug etc.
  • Agent24
    replied
    I may have missed it but I didn't see anywhere where you actually tested the relay to see if it still works and that the contacts are not burnt or gone high-resistance.
    If the burnt trace was caused by burnt contacts in the relay, leading to excess heating of the contacts, and thus burning of the PCB as well, then you still have a problem.
    Heating the relay to soldering temperature while doing the trace repair may have finished the relay off, if it was already damaged.
  • Eaglecrest
    replied
  • lotas
    replied
    Did you connect all the wires correctly and didn't mix anything up?
  • R_J
    replied
    What I am saying is that trace repair should not cause the board to be dead, you must have done something else, if you remove the wire do you think the board will start to work as before? the wire only replaced the trace it did nothing else. Maybe there are other poor solder connections on the plugs.
  • Eaglecrest
    replied
    Here are some pictures of the job, not pretty, but I am getting continuity from input post to the wire joint at the relay. So that solder job worked. Can't tell if the relay is making contact, but don't understand why it wouldn't. Your confirmation that relay should not suffer from the solder work means that it is dead because of that solder joint. I can try to reflow and add more solder. I used 60/40 solder and it seems like it was lead free solder originally, it was my understanding that mixing them shouldn't be an issue. Is this a wrong understanding?
    Not sure I am understanding your comment, "the trace connection to the relay was not making connection". Regardless of the trace connection, the wire parallels that connection and will either replace it or combine with it. So as long as the wire makes a connection to the relay post all should be well.
  • R_J
    replied
    Without any pictures of your repair job, it's hard to comment. the trace connection to the relay was not making connection, if it didn't get soldered properly the fault would be the same, the heat would not have hurt the relay. check your solder connections, check that you connected everything correctly
  • Eaglecrest
    replied
    I had a difficult time getting the old solder off. I needed to go to about 410 degrees to get it to melt. That seems rather high, but it was what it took. I was able to get the power strip connectors cleaned, but the relay never came clean. I used a solder sucker and copper braid, but I never seem to be able to get the braid to work. Thoughts and suggestions regarding these observations?
    So I soldered a stranded 16G wire between the two points and the board is completely dead. Previously it would startup, but then die shortly after use. The power connection to the other end of the wire showed continuity, but there is no way to check if the relay is actually getting power. Not sure if there is a problem with my solder job or if the heat caused an issue with the relay. Seems like a relay shouldn't be too delicate. Any thoughts on this result?
    Seems like a stranded 16G is over kill; I am thinking that I would be better with a solid wire would be better that could be put into the through hole next to the post and that should be a better solution. I am assuming that i need a reasonably significant gauge to carry the needed current, how do I determine the appropriate gauge?
    I have ordered a new, used board which should at least get the dryer up and running again, but I would like to play with the old board and see if it can be revived. Suggestions/insights would be appreciated.
  • R_J
    replied
    Just repair the trace already, the length of the wire is so short that 18 gauge would be fine, it is very likely that that relay pin did not get enough solder when manufactured, so over time the connection weakened and once it got loose started to arc, Install the jumper already and try it. If you want to replace the relay go ahead and do it.
    Like I already said, resolder ALL the relay pins and also the connector pins as they usually do not get enough solder when they are made. If it is the Omron G8P-1A4P, here is the service life for that relay
    replied
    most dryers use the same motor for the drum and the air circulation fan.
    if that doesnt run the heater will get too hot and that will get detected.
    if it's an electric heater anyway, gas ones must have a heat exchanger and more safety devices.
  • Eaglecrest
    replied
    R_J, that is my understanding. A couple of followup questions. Would an 18G wire be sufficient?
    As I look at the schematic, it seems like when energized the relay turns on the motor. It seems like, therefore, if the relay goes bad then the dryer should function in every way, except the motor wouldn't come on and thus no clothes get dried. In my situation, nothing happens. The light inside the drum is on, but the control panel does not come on nor is there any kind of operation other than the interior light. Thus I am assuming that somehow the controller chip is monitoring this and is shutting the system down when the relay fails, does this make sense to you?
    To further my thinking, I found a "repair kit" on eBay which is just the relay; as I mentioned earlier, i bought a replacement board that worked the same as my board (runs the dryer for a short period then shuts down the system with a blinking light and no activity with the buttons requiring a power reset). This replacement board had what appeared to be a new relay (different than the relay on my board) and it appeared that the trace got damaged when it was removed as half the distance of the trace from the replay post to the power connector post was solder. I am assuming that the solder repair wasn't working and that was causing the failure after a short system run.
    My dryer worked fine for years (at least a decade) and I am further assuming that after years of use the relay power connection weakened the connection to the board and has progressively caused cause the solder connection to deteriorate. I further assume that a relay will either work or it will fail so it seems that the problem is more likely the connection from the relay to the power strip than the relay itself. Do all these assumptions make sense or am I off base?
  • Eaglecrest
    replied
    STJ, don't know how you got your understanding. I thought I was quite clear that I am looking to deal with a bad trace between the relay and the power connector. Bypassing the relay would have the motor running full time regardless of the setting. I don't see how that could possibly be a good idea. You never asked for clarification nor mentioned that would be a bad idea, if that was your thought.
  • R_J
    replied
    Looks like the relay is for the Motor, It looks like a common problem with that connection going bad, I would repair the connection like I suggested and it will likely solve the problem. it looks like it is a 30 amp relay
    replied
    i think he is refering to bypassing the relay.
  • R_J
    replied
    There is nothing wrong with hard wiring the burnt trace, it is done all the time that is likely all that is wrong, clean the relay pin so you can make a good solder connection to it. Resolder any other similar large connections adding more solder as required,
  • Eaglecrest
    replied
    Why can't someone answer the base question? I can appreciate that the relay may well be the cause and to really fix this the relay may need to be addressed, but is there a problem if I hard wire to make sure the problem is the relay and not the trace?
  • CapLeaker
    replied
    Same as: if a relay clicks when energized, doesn’t automatically mean it is good. As far as that black spot on the PCB: take the coating off, unsolder the relay, check these relay by energizing and de-energizing the relay and checking the resistance while doing so. Clean the board resolder the relay if it is good or replace with a new relay, if you aren’t sure. Verify the PCB ais working and go from there.
    replied
    most likely if you have 2 with burned pads the relay is burning inside and the heat from that is burning the pad.
    it needs a better quality ore higher current relay.
  • Eaglecrest
    replied
    I appreciate your advice, but you aren't answering my question. I don't see why I would need to remove the relay. It seems to work fine, when the board works. I would assume that a relay either works or it doesn't. Why would a relay work for a while, then stop and after "resting" work again?
    Additionally, I purchased a used replacement board that had the same problems. Close examination of this board showed it had the relay replace and it appears that when the relay was replaced the trace I am asking about direct wiring was damaged and soldered to repair it. So I am guessing that if the trace has an issue it will cause the controller chip to see an error and shut down the system. It seems the best way to test this out would be to run a wire directly from the relay post to the power connector post, which is what the trace in question connects. So the question at hand is if there is any reason to believe this would work or would cause a problem. I don't see why, but am asking for advice from people wiser than me.
    Stated another way, if the problem is the trace then I can replace as many relays as I would like and never fix the problem.
    replied
    remove the relay and sand/ file the contact and check the case isnt melted around it.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • Joe24
    Maytag Whirlpool Kenmore clothes dryer data bus
    by Joe24
    Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
    Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
    I've been over the board looking for...
    01-13-2025, 06:50 PM
  • notallbad
    Indesit vented tumble dryer control board dead
    by notallbad
    Anyone able to help diagnose the fault with this board please.
    Hopefully photos are clear enough to give me direction on what readings to take and where.
    All ancillary components of the dryer have been tested and work i.e heating element, thermostats, sensors, motor, door switch, wiring harness.
    So theres 230v at the control board but no life whatsoever with or without the ancillaries connected.
    The on/off/timer dial contacts are clean and make good contact. All the through hole mounted components appear to be good i.e diodes, resistors,...
    01-04-2023, 05:49 AM
