LED lamp
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    LED lamp
    I have a multi-colored RGB lamp that constantly switches to different colors. Can you tell me how to make it so that only white light constantly glows?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    simplest way is probably to short the collectors of the three transistors QR QB QG (collectors are the pins nearest to those Qx letters) together and to the white wire, GND.
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      Thank you so much 🙏🏻. It worked 🥳🫶
      • vestaviascott
        Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
        by vestaviascott
        Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
        Here's what happens:
        1) Power on
        2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
        3) Blue status light flashes for appx 4 minutes...
        07-29-2020, 06:08 AM
      • mikey5791
        Help on Samsung Syncmaster T220 dead ccfl lamp
        by mikey5791
        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
        10-18-2020, 03:17 AM
      • khelane
        test active pfc power with lamp test
        by khelane
        Hello
        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
        Is there a way...
        06-03-2025, 01:00 AM
      • unimatrix93
        Inexive (Vestel) TV constantly blinking after plugging in
        by unimatrix93
        Hello everyone, I have a constantly blinking Inexive LED TV.
        Display is: VES390UNVA-2D-N01
        Mainboard: 17MB97​
        PSU: 17IPS71
        The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
        03-26-2025, 08:36 AM
      • Yanleb
        Sharp LC-60LE810UN Lamp Error
        by Yanleb
        I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
        I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
        Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
        I've tried all the key...
        08-24-2021, 11:48 PM
