BOSCH Microwave CFA634 error E1006
  • AlexVG
    • Apr 2022
    • 135
    • SPAIN
    I have Microwave BOSCH CFA634
    It runs, but after 10 -15 seconds stops working.
    Sometimes it shows error E1006.
    I can't find this error explication.
    Some people say it's communications error between main and display module.
    Probably somebody has an experience with this issue?
    Can you help me please?
    Thank you an advance.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8293
    Sounds to me like the magnetron is getting shut down maybe? Bosch, Siemens and Neff had these problems and the internet is littered with it, but just not if you are using Google as a search engine.
    Some say it's a comms error, I just find it funny there is the same comms error always occurring 15 seconds down the road. Another is changing boards out (display and main board) until it works again. So is there a definitive answer? Probably not.
    • AlexVG
      • Apr 2022
      • 135
      • SPAIN
      Thank you for the answer.
      Yes, in case of the Neff E1006 means magnetron issue.
      I have checked exchange between mainboard and inverter board. And I don't find out any problems.
        • 31158
        check the electronics first.
        too much shit in these modern devices to go wrong - specially psu's for microcontrollers.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8293
          I hate these YouTube fix videos where one is changing one board after the other one until it is fixed. It goes like this: First change board A. If you still have the problem, exchange board B. Still have the same problem change board C... etc... Its just like emptying the parts cannon and by the time it is fixed you could have replaced it twice.
          • AlexVG
            • Apr 2022
            • 135
            • SPAIN
            Hi.
            Here is exchange between main and inverter board.
            I am guessing to magnetron or inverter problem.
            https://mega.nz/file/upd1iYxY#19aVEq...KwmQ95xoX5fiLk
            • AlexVG
              • Apr 2022
              • 135
              • SPAIN
              • AlexVG
                • Apr 2022
                • 135
                • SPAIN
                I tried to initiate the problem of a disconnected high voltage magnetron line.
                I received error E1007.
                Below is the video.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8293
                  I suppose if the inverter board shuts down, so does the magnetron. Question is what does the inverter board see or doesn't see after 15 seconds of run time? Try running the microwave on different power levels and see if it changes anything?
                  • AlexVG
                    • Apr 2022
                    • 135
                    • SPAIN
                    Good idea!
                    It works at 10% (90W) of power
                    at 360W - the same problem
                    • AlexVG
                      • Apr 2022
                      • 135
                      • SPAIN
                      This part means that it is not communication error between main and display module.
                      Good news!
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8293
                        I had a hard time believing it being a comms issue after 15 seconds every time. Didn't make any sense. Now... is the problem the inverter board, or is it the magnetron? I am still suspecting the magnetron.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8293
                          unplug the magnetron and take it out. Masure the resistance between the termials and the magnetron body. It should be high in resistance.
                            • Jul 2011
                            • 6057
                            What comes to mind is either the magnetron is pulling to much current at 100% output or the inverter has the same kind of issue pulling to much currently or the feedback circuit has some kind-a problem or it has a communication problem now how to troubleshoot this issue is probably going to be a challenge because it depends on the protocol that it is using optical fly wire some other name and unfortunately there so many types who know what they used to do the communication protocol
                            Do this testing at your own risk do not do this for more than 15 seconds at a time and wait 3 minutes between each test
                            Now you can do this test if you have a fluorescent light bulb tube that is about 3” long and no longer than that tape the connection ends and put in the center of turntable and turn the microwave on low power at 10% does the fluorescent bulb flicker the same all the way around the hole 360'D if so then do it 50% power do you get the same results the flickering should be a little bit brighter then do it at 100% dose it at any time start flickering and stop and start flickering again if so then it might very well be a over current situation
                            Now there is a situation where you can have a carbon build up in the magnetron track to the inside of the cabinet if this is the case you might hear a buzzing sound and the flickering off the fluorescent bulb might erratic in its flickering if does and to make sure that it is that the fluorescent bulb is too much in the center of the turn table move it about an inch in one direction and do the test again is the flickering more evenly spread out if it still erratic then I would suspect that it might be arcing in the channel that I referred to earlier if that is the case and if you can still find it “microwave safe paint “ it used to come in little bottles like fingernail polish does and what you would do is sand the the carbon off wipe it down really good and repaint it so that you could stop from arcing
                            Just before it stops running dose the flickering get real bright before it shuts off
                            • AlexVG
                              • Apr 2022
                              • 135
                              • SPAIN
                              Thank you.
                              So.
                              I have just connected inverter board to pulse generator.
                              Inverter is working, magnetron heats up.
                              But test lamp and field detector inside of the box shows nothing.
                              Here is the link to the video of my experiment.
                              • AlexVG
                                • Apr 2022
                                • 135
                                • SPAIN
                                • AlexVG
                                  • Apr 2022
                                  • 135
                                  • SPAIN
                                  Yes. Have done. All measurements look good.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8293
                                    What about the high voltage capacitor? Maybe it doesn’t have enough oomph?
                                    • AlexVG
                                      • Apr 2022
                                      • 135
                                      • SPAIN
                                      I guess it's a magnetron issue.
                                      However, it's not available at the Bosch originally spear parts.
                                      https://www.bosch-home.es/catalogo-e...lebox=manuals/
                                      • AlexVG
                                        • Apr 2022
                                        • 135
                                        • SPAIN
                                        https://spares2repair.co.uk/bosch-si...etron-12006667
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          Replaced emmc.
                                          Terminal log
                                          UART
                                          AC_ON
                                          E-B
                                          FDE enabled
                                          06-01-2025, 02:11 AM
                                        • mariukonie
                                          Neff C67M70N0GB-09 fault code error E300 - How to fix it?
                                          by mariukonie
                                          Neff C67M70N0GB-09. After a power grid failure, when the operator turned the power back on, there was some overload, because the oven shows error E300 and nothing can be done, even the clock cannot be set. From what I knew, the operating module (the one with LCD displays) was damaged. Can anyone advise how to fix this? A new module is very expensive, so I would rather repair the one I have. Thanks in advance for your advice ....
                                          01-21-2024, 02:46 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • Curtissimo
                                          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                          by Curtissimo
                                          Hi everyone.
                                          I have a HP Elitebook 850 G8.
                                          Serial: 5CG2324XM0
                                          ProdID 6L8D5EC#ABA
                                          It has a Winbond W25Q256JVEN Chip.
                                          I need to remove BIOS Password.
                                          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                          Attached my dump.
                                          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                          What I did:...
                                          08-26-2025, 04:42 AM
                                        • Maalobs
                                          Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                                          by Maalobs
                                          I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                                          The relevant service manual for the chassis is available here.
                                          The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                                          When I short the SDM to ground I get the layer-2 error code 53.
                                          The inside of the TV has no damaged components and no swollen capacitors.
                                          In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                                          04-02-2019, 01:15 PM
