Neff C67M70N0GB-09 fault code error E300 - How to fix it?
  • mariukonie
    • Aug 2023
    • 29
    Neff C67M70N0GB-09. After a power grid failure, when the operator turned the power back on, there was some overload, because the oven shows error E300 and nothing can be done, even the clock cannot be set. From what I knew, the operating module (the one with LCD displays) was damaged. Can anyone advise how to fix this? A new module is very expensive, so I would rather repair the one I have. Thanks in advance for your advice .
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    I suggest you post some straight shot, high resolution pictures from front and back of the board, so we can see something.
    • mariukonie
      • Aug 2023
      • 29
      Thanks. Please ignore some bad looking solder​s as I was already trying to diagnose it a little bit.Click image for larger version
ID:	3185971 Click image for larger version
ID:	3185973 Click image for larger version
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        You do have to fix your soldering. I am guessing so far same thing. It couldn’t have been the caps, since it is saying E300 and isn’t completely dead or something. But there are individual voltage regulators, protection diodes and regular diodes and transistors. Is there a sort of paper schematic the oven came with? Should be in a pouch somewhere on the back of the oven.
        • mariukonie
          • Aug 2023
          • 29
          I know my soldering is bad, I'm working on it I don't have sny schematics unfortunately but the orange cables are the ones that come in from main control pcb so they are supplying module with power hence I would guess that's where surge of power would come in What would be the most likely culprit? All black cables go to control knobs on the front panel.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            Some are doing some sort of reset. Look at this: https://www.youtube.com/watch?v=u5Pv2ucxdxE
            From what I also gathered, it has something to do with the firmware. If you can't do that reset apparently the firmware is bad.
            Here another snippet I found:
            Error E300 occurs due to inconsistency between the instructions of the control board and the module with the software. In other words, this is an electronic unit error.
            It is difficult to find detailed information about this error on the Internet, because to eliminate it you will need to get into the “electronic brain” of the oven and make some changes.
            The problem can have two solutions:
            1. Partial change in the program code (with the error constantly blinking).
            2. Complete code update (if the error is static).
            If you encounter such a malfunction, we will help you fix it. Most often, the technician will perform the work of reprogramming the module at home, with rare exceptions - at a service center.
            Now how they flash that thing and with what I got no idea.
            Here is something out of the manual:
            The temperature display shows, “EXXX”,
            e.g. E300
            Internal fault in the appliance electronics Press the .- clock function button. If the
            message does not go out, pull out the
            mains plug and plug it back in again after
            approx. 10 seconds​
            • mariukonie
              • Aug 2023
              • 29
              Thanks. E300 on mine is static, I did put it into test mode as shown in video and it was testing everything fine but there are some settings that I don't know what they mean, Should I just try different settings on a hit and miss basis?
              Pressing clock button and unplugging for 10 seconds also didn';t help.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8340
                Maybe take some more pics. In any case it doesn’t look good if you need to have your firmware flashed.
                • redbomb65
                  newbe
                  • Jan 2024
                  • 17
                  hi,
                  i did some research, in my simens service programm, and found: e300 1. wrong modul kombination {screen <--> control pcb} 2. wrong variant code.
                  what i read you can programm or change the code. You need access to the testing program in the device. Then the type plate is still required. Then a number must be converted into a hexadecimal number and then changed on the electronics. then the device should work again. Unfortunately, there is no PC access (i-service) on the device. This means that if this doesn't work, one or both electronics may need to be replaced. because the program is permanently stored on the ICs.
                    • Jul 2011
                    • 6069
                    I am NOT impressed with this controller board at all for it to go into an error message that is not recoverable what nonsense is this crap this almost as bad as what Whirlpool did few years back with some of controller boards on some of their refrigerators the only thing you could do was replace the controller board
                    Other manufacturers have done this from to time make devices that there is no way to repair them without going through the manufacturer this more crap this nonsense even done with industrial equipment as well and just want to strangle the people who do this crap
                    And what is worse is not to offer a solution for the problem with controller and you search far and wide to maybe find a solution to the issue at hand REALLY I would never knowingly buy a product that controls your life that way
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      Originally posted by redbomb65
                      hi,
                      Yeah I did look for some test points on the board and didn’t find any. Not saying there aren’t any… However maybe the chip can be taken off and reprogrammed / replaced.
                      So you take the type plate, convert certain numbers to hex and insert these somehow in service mode? Interesting. I couldn’t read the part number of the IC so not sure what it is.
                      • redbomb65
                        newbe
                        • Jan 2024
                        • 17
                        i will post a part of the service manual. but its only in german. google tanslator will help
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8340
                          no problem, post the german service manual.
                          • lotas
                            • Jan 2016
                            • 4786
                            • Russia
                            I couldn't read the part number of the IC so not sure what it is.
                            Microcontrollers used here are from Renesas.​
                            • Curtissimo
                              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                              by Curtissimo
                              Hi everyone.
                              I have a HP Elitebook 850 G8.
                              Serial: 5CG2324XM0
                              ProdID 6L8D5EC#ABA
                              It has a Winbond W25Q256JVEN Chip.
                              I need to remove BIOS Password.
                              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                              Attached my dump.
                              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                              What I did:...
                              08-26-2025, 04:42 AM
                            • Maalobs
                              Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                              by Maalobs
                              I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                              The relevant service manual for the chassis is available here.
                              The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                              When I short the SDM to ground I get the layer-2 error code 53.
                              The inside of the TV has no damaged components and no swollen capacitors.
                              In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                              04-02-2019, 01:15 PM
                            • bohaboha
                              error code 0x80072f8f 20000 When widows upgrade to 10
                              by bohaboha
                              when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
                              in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
                              Error Code 0x80072f8f 20000
                              08-30-2023, 07:06 PM
                            • Sus256
                              HISENSE 65E7KQ PRO - no boot
                              by Sus256
                              Hi all!
                              HISENSE 65E7KQ PRO
                              RSAG7.820.13512 - chassis
                              MT9618BAATAB - cpu
                              RSAG7.820.12059 - power
                              HD650Y3U77 - panel
                              KLM8G1GETF - emmc
                              Replaced emmc.
                              Terminal log
                              UART
                              AC_ON
                              E-B
                              FDE enabled
                              06-01-2025, 02:11 AM
                            • CdDvdFlash
                              Hitachi HTA-DD3W AV Receiver Error Code -Protect-
                              by CdDvdFlash
                              I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
                              07-10-2023, 06:05 AM
