UNOLD Elegance Typ no. 58105 induction hotplate - Component identification
  • mabinternet001
    • Sep 2017
    Hi, I need help to identify the component with marking "9003 KAUCHB".
    A bit of background...
    I have an induction hotplate UNOLD Elegance Typ no. 58105 (with board CHK-A1.42S) which has a blown resistor.
    I have also located the problem in the SOT23-6 component with the marking "9003 KAUCHB"; the pin 5 was disconnected from the IGBT emitter (ground) due to the high temperature and this caused the IGBT to be permanently ON.
    I replaced the resistor and resoldered pin 5 of the SOT23-6 component to the IGBT, the hotplate worked for about a month and failed again due to the resistor (which I replaced with the correct resistance and wattage).
    I now suspect that the SOT23-6 component marked "9003 KAUCHB" may be failing, due to the high temperature surrounding it, and I would like to replace it. Does anybody knows which component is it?
    By the way, I think pins 2 and 5 are connected together; it is what I remember from the last time I repaired the board.
    Thanks in advance
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8177
    You say the resistor goes open due to heat? Increase the wattage of the resistor or airflow. Would be my first ticket. Did you use silver solder?
    • mabinternet001
      • Sep 2017
      The component with marking “9003 KAUCHB” controls the IGBT “20N120”. In a normal operation, the IGBT only “pulses” to create the magnetic field in the main coil. If the IGBT fails and gets shorted, full power will flow throw the coil and it will burn the whole appliance. The now-blown resistor is in series to prevent this situation as it will cut the current flowing to the main coil when it burns itself (that is my understanding).
      The component “9003 KAUCHB” is located in a bad place on the board, next to the IGBT, where a lot of heat is generated. There is a track under “9003 KAUCHB” from pin 5 (and I think also from pin 2) to ground (the emitter of the IGBT). This track is not visible on the photos, but got disconnected when the induction hotplate failed for the first time. The heat on the emitter was high enough to burn the thin and narrow copper trace going to the “9003 KAUCHB”.
      When the “9003 KAUCHB” loses ground, the gate of the IGBT is always high. This situation is similar to a shorted IGBT when a permanent flow of current goes to the main coil. And this is when the now-blown resistor is relevant because it burns itself and cuts the flow of current.
      I would like to replace the “9003 KAUCHB”, but I do not know what component it is. However, I have also thought in increasing the wattage of the 22 Ohm resistor from 3 to 5 Watts and see if the problem is solved.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8177
        That's why it IS important to post a straight shot, high resolution picture from both sides of the board and not just snippets. What I do see is that this big inductor got hot and discoloured. May be worth checking. I think the power goes through the resistor into your induction coil to your IGBT. There should be a capacitor in parallel with that resistor and induction coil. So this should be a tuned tank circuit. If that capacitor changes in value, I would think it should sour your day and could cause the IGBT to blow again and again after a while.
        • mikkele86
          Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
          by mikkele86
          hello.
          I have two power amplifiers, both having their IGBT blown on the PSU.
          The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
          I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
          I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
          So I though i missed a capacitor or diode. I removed...
          01-06-2024, 06:45 AM
        • _ASH_
          Induction hob issue
          by _ASH_
          Hi Guy's, I currently have a Beko induction hob (Model: HII64201MT) and the right hand side dosn't detect the pans.
          The left side works perfectly, but when I put the pans on the right side, the digital display displays U and I don't hear any clicking (like it's trying to detect the pans)
          Can anyone advise me on this & to what parts I will need to repair?
          Many thanks in advance
          Ash...
          07-30-2025, 02:48 AM
        • sarry86
          Need help with IGBT 1450va ups/inverter
          by sarry86
          Hello everyone, I have this ups/inverter IGBT 1450VA which was working great until it started showing short circuit on a small lcd screen, I opened it up and started troubleshooting it and indeed I found some fault transistors, I decided to get rid of all of the transistors next to the shorted ones and it worked for some minutes without a problem, but then I heard a relay tripping off, and now it is showing that 2 batteries connected in series have no power at all, and if i disconnect the 24dc in then the battery are showing they are full (28vdc) with another inverter, they are working great no...
          09-24-2023, 06:17 AM
        • tibd
          Help with parkside induction cooker controller IC.
          by tibd
          Hello.
          I am troubleshooting a parkside induction cooker. The bord had a microcontroller ic with marking IH001 (dip24) which i think is faulty. Any ideas what this IC is, to purchase internationally? Otherwise there is a VIPer12a which seems working fine. No other defective components were found.
          Best regards.
          12-26-2024, 10:11 AM
        • jm1234
          Siemens induction panel PCB burnt
          by jm1234
          this is a Siemens induction panel, one side seems damaged, I attached both good and burnt picture to compare. I'm not sure what those rectangles a are for, but they are connected by a solder. That seems to be what got burnt, so I'm wondering it that was some kind of a protection. Do I just try to re-solder them?
          Thanks,
          Daniel...
          01-15-2024, 01:22 AM
