Induction hob issue
  • _ASH_
    • Dec 2011
    • 14
    Induction hob issue
    Hi Guy's, I currently have a Beko induction hob (Model: HII64201MT) and the right hand side dosn't detect the pans.
    The left side works perfectly, but when I put the pans on the right side, the digital display displays U and I don't hear any clicking (like it's trying to detect the pans)
    Can anyone advise me on this & to what parts I will need to repair?
    Many thanks in advance
    Ash
  • Gjackson
    SMEG induction cooker error EA on both left hand side cooktops
    by Gjackson
    I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
    07-09-2024, 01:46 PM
  • speggio91
    Macbook Pro A2251 820-1949 5V cycling
    by speggio91
    Hello everyone, I've searched the forum but couldn't find a case with the exact same symptoms, so I'd appreciate some advice.
    I'm working on a macbook pro late 2020 with the board 820-1949. The laptop came in with visible liquid damage and corrosion in various areas:
    -speaker amp right side (C6483, C6455) - no shorts detected
    -keyboard backlight area (pin 2 of J8401 was destroyed plus some minor corrosion)
    -C2070 corroded under the pads
    -The most afflicted area is around UB260, RB296, RB29A, RB291, RB263, U3100_R (just a bit on the right side), all the area...
    03-31-2025, 05:14 PM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
