Fridge ice disp ok, water no go!
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I got a friend with LFX25960SW, it will dispenser ice but not water.
    I checked the tube for blockage by disconnecting and blowing through it and it was fine and obviously water is getting to the ice maker.
    I check the water valves which has three in the system, one for ice, one for water and one for a primary (pilot) shut off. Obviously primary shutoff works fine and ice works fine too.
    After ohm testing the coils on the water valves that come out to 360 ohms each, I tested for voltage. Well I get no voltage on ice solenoid which I shouldn't get but on the water solenoid I get 104v on purple and on white!??!?!, obviously something is shorted. Also when water tube is disconnected from water valve it doesn't trigger the pilot valve either, but every time I switch to ice the line is full of water.
    I checked the dispenser lever switch, it tested ok.
    Now if you go to the diagram on page 5 of the service manual look at "PWB ASSY, DISPENSER," it's not accurate some of the connectors are reversed.
    But it does wire in the same manner.
    White/purple/black/skyblue/red should be on or off depending on the setting. If I select water then obviously red/black/skyblue/white should be off. I'm not sure how the dispenser door and ice water valve work, if black handles the dispenser door or if red does, because the ice water valve has red and blue wires, but a black wires goes to sole. cube on the board and blue is "N" for load/neutral/grounded conductor. I didn't get a closer look at the dispenser door, I should have.
    Well here's the problem, all the relays are closed except for the auger in the ice maker, when you remove power they return to their open state but apply power and all the relays close. I removed the DISPLAY assembly connection to this small board and all the relays are still closed. obviously it shouldn't be. My guess is an IC crap out. I tested the zeners and diodes then resistors which leaves two small IC (ic2 ic3), cc1 cc2 and a 7 circuit darlington transistor.
    My money's on the darlington transistor.
    I can smell what appears to be electronic burning odor residue, strongest around the darlington transistor.
    It's KID65003AP
    Am I correct to assume this is the fault?
    My guess for a replacement would be one of the these?
    http://www.digikey.com/product-searc...=0&pageSize=25
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Fridge ice disp ok, water no go!
    Put meter on diode check put black probe on pin 8 of the KID65003AP and test pin 16 to 10 for shorts.
    then put red probe on pin 9 and with black check pins 10 to 16 for shorts.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Well I can't get a good reading, I get 742 ohms for 11,12,13,16 going from common pin 9 to them. I get 360 ohms from 9 to 10. 14,15 are not connected and get infinity on them. Going from ground to 10-16 all open unless I switch the probes around then I get 749 ohms. Seems like the relays are throwing my readings off. But then again if it going through the relays then it's not shorted correct? so whats causing it to close relays when it's disconnected from the display/logic board?
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        I just had a random brain fart, but uh, if I disconnect the display/logic board which provides 5v and 12v needed for the relays and ICs then shouldn't this not work at all?
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Exactly with that connector disconnected nothing will happen.
          Your test results show the chip to be ok there are protection diodes built in to it.
          I think that is what your meter is picking up.
          the connector that goes to logic board has
          1. 12 volt power for relays
          2. 5 volt for "I/M-S S/W" and "PADS/W" sense fror something
          3. ground for 12v and 5v and control signals and sense
          4. AU, auger motor control
          5. SO, sole cube
          6. W-V, water valve
          7. S-D, sol - disp
          8. D-L, dispenser lamp
          9. HTR, heater
          10. PADS/W, sense for something
          11. I/M-P S/W, sense for something
          My pc
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            void post worked out how to get water below
            My pc
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              and the two sense wire are for switches
              My pc
                So what AC voltage do you get at the 'N' Neutral pin and the 'WATER VALVE' PIN on the board when water dispenser switch is activate. What color wire is on that WATER VALVE connector on the circuit board. The water solenoid should have one of the terminal connected the N neutral.
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  When water dispense is on and trying to fill cup you should have 115vac between red of con 3 and black of con2.
                  Do you get that?
                  My pc
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    ninja posted by budm
                    My pc
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      he is looking for line voltage between red on con 3 and black on con 2
                      aka N on con 2 and sol disp on con 3
                      water valve is to fill ice tray.
                      My pc
                      • Mad_Professor
                        A Mech Warrior
                        • Feb 2011
                        • 1587
                        There's two water valves in the fridge door, ice valve had red and blue, water valve has purple and white. Purple goes directly to this board and the white does not ground but goes to the dispenser switch but also to "PADS" on the board. The dispenser switch also has blue connected and I'm pretty sure that goes back to neutral. Since PADS doesn't have a relay and is handled by ic2 I'm not sure how this works, if I select water, ic1 pin 12 should trigger ry3 which will close and provide 120vac to the water valve solenoid assuming that the dispenser switch closes and completes the connection to ground/netural, but why am I getting 104v through white???
                        To answer your question, I get exactly 104vac on all relays when they should be open and no power on the output, but that's not whats happening, I assume they are open since connector that supply 5v/12v is disconnected, so something is backfeeding 104v in the fridge and I don't know where.
                        I'm going back out sometime this week, maybe tomorrow after work and ohm out the wires, test the board pin out, test the hardness live and see which one has the crappy 104v coming back through, worst case disconnect everything and plug one thing in at a time.
                        Also ic2 ic3 are NEC "2561 DJ643"
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          dispenser level switch provides the connection to neutral for
                          ice tray water aka water pilot valve marked as water valve on con 2
                          solenoid cube marked as sole cube on con 2
                          auger motor.
                          for water dispense solenoid one side should be connected to neutral and other to sole disp on con 3.
                          please check neutral is connected between plug of fridge and N of con 1
                          My pc
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            ic2 ic3 provide feedback to display board tells it whether ice maker is on via ice maker power switch and if ice is full via dispenser lever switch.
                            white has a connection via D2 D3 IC2 R1 to line.
                            white is only connected to Neutral when dispenser lever switch is closed, otherwise it floats.
                            My pc
                            • Mad_Professor
                              A Mech Warrior
                              • Feb 2011
                              • 1587
                              Ok so that's what I thought, it floats and allows voltage to water valve, when the dispenser switch is closed both are grounded completing both circuits, then the water valve solenoid is just bad? The only way to test that is to wire directly to a plug and connect to an outlet and see if it actually works.
                              also I will test supply voltage to make sure it's not just low voltage issue.
                              Edit: I think the ic2 is to signal the display/logic board when the dispenser lever switch is depressed by the user, to send voltage to the darlington transistor array which then engages relays ry1 and ry4 which opens the dispenser door, starts auger motor. The cube solenoid is probably for it's water valve, since the ice maker is a stand alone unit only sends a signal to this board when the trays are empty and needs water.
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                ok so for water to work ry 3 needs to be closed and dispenser lever switch needs to be closed.
                                do you get line voltage across the water valve when there should be?
                                It might a good idea to test the solenoid to see if it operates.
                                you can also connect a low wattage 110 volt bulb across Purple and white in place of the solenoid if lights when water should come out the control is working.
                                My pc
                                  "I get exactly 104vac on all relays" You can see that the Line (120V) is fed to the all the relay contacts, the output contacts then are routed to the output connectors on the board, so that is why I asked to check the voltage on the Line and Neutral on the board to see if you are getting 120V @L & N, and N and all the relay out puts.
                                  "ninja posted by budm"????????
                                  • Mad_Professor
                                    A Mech Warrior
                                    • Feb 2011
                                    • 1587
                                    Well reinstalled board, test water solenoid in the door for power. When pedal is depressed, it reads 120v so that's good, disconnected the tubes and depress the pedal again but no water coming from main. I pulled the fridge out more and remove the floor panel to gain access to the "inlet valve" (what it says on the back of the fridge.)
                                    Turns out this is a double solenoid single valve vs the door which is a double solenoid double valve. I tested the solenoid for voltage and had someone depress the pedal on the front, got 120v as well but I heard a vibration coming from tube, disconnected the tube no noise, put my ear up against the solenoid heard a faint buzz, no water coming out.
                                    So inlet valve is bad, water/ice valve in door ok.
                                    Sad thing the part is hard to find, but we found a substitute.
                                    When that comes, I'll update this thread if it fixed the problem or not.
                                      I get most of my appliances repair parts from appliancepro.com
                                      • Mad_Professor
                                        A Mech Warrior
                                        • Feb 2011
                                        • 1587
                                        ok so I got the valve but it did not come with the wiring harness as shown in the picture. In the picture it shows the wiring harness with a blue box, black wires coming from the solenoid to this blue box and with purple and red tied to together in the connector and ground(blue) to ground. After examining other photos from various sites, I found one that show a clear picture of the blue box and it's a film capacitor mkp wk1118. Now why would a solenoid need a film capacitor? doesn't make any sense.
                                        Anyways I took the old hardness and spliced it, hot connector to hot connector then to sliding connector and ground to ground, water valve worked with no problems, but still curious on why a solenoid would need a mkp when there is a relay upstream that connects it directly to 120v line.
                                        Guy is happy that he has water working.
                                          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                          by sam_sam_sam
                                          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                          04-09-2023, 08:04 PM
                                        • CapLeaker
                                          Kenmore Elite Fridge Water / Ice dispenser not working, Maytag 12920710 (fixed)
                                          by CapLeaker
                                          A few days ago my Kenmore Elite Fridge, Model # 596.77533600, quit dispensing water and ice. The display on the fridge was still working, the micro switch on the dispenser tested good, but it was intermittent dispensing water. Mostly actually it was not. Really weird. Sometimes it would dispense water and ice with the right fridge door open, but not when closed.
                                          After a while I came to the conclusion there is trouble on the main HV board on the back of the fridge. The HV control board # Maytag 12920710. Nothing out of order when you look at it. Then I began...
                                          08-31-2017, 06:30 PM
                                        • Ugur87
                                          MacBook Air M4 A3240 Brand New Water Damage no Image
                                          by Ugur87
                                          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                          08-28-2025, 01:09 PM
                                        • edugimeno
                                          Stagg sms12p audio amp has water damage
                                          by edugimeno
                                          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                          There is only one signal wire connecting the first boards...
                                          05-24-2025, 06:00 AM
                                        • RetroComputingGrotto
                                          Water Damaged Toshiba 48L1435DB
                                          by RetroComputingGrotto
                                          I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                                          The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                                          10-07-2024, 08:23 AM
