dead transformer on ceramic oven
  • Wolf1977
    • Jul 2023
    • 59
    • Greece
    hi in ceramic oven the transformer is damaged
    and writes
    2x115v/2x12v/6VA 50-60hz ta105/f
    can you suggest me a compatible transformer ;
    i have found in 70 degrees celsius do you think is suitable for ceramic oven ;
    • 31044
    Re: dead transformer on ceramic oven
    got any pictures?
    how is it wired, is the 115v windings in series for 230v?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      His location says Greece so it's most likely 230V.
      A working TV? How boring!
      • Wolf1977
        • Jul 2023
        • 59
        • Greece
        yes right
        is connected in series 230 volt power supply and the output has 2 x 12 volt ac
        and hat to connected 0 of first coil connected to 12volt to second coil and to ac pin of bridge rectifier
        and the 12 volt of the first coil connected to 0 volt of secondary coil and goes to the other ac pin of bridge rectifier and eac coil must be 3va 250 ma fuse
        so accordingly the above connection the bridge has 24 v ac input ; i ask because i am thinking to test the pcb with an external power supplu just to be sure
        but the temperature enviroment is 105 degree celsius because writes 105ta/f
        all the transformers i have found until now is ta 70 degrees
        furthermore the transforer is solder on pcb so i have to find a transformer with the same pins to solder on the pcb
        the device is ceramic oven
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          105/70C is the temperature the thermal fuse inside the transformer burns at. I doubt the PCB reaches anywhere near 70C as there must be some capacitors on it as well. I would say go ahead with the transformer with 70C fuse If all other parmeters match.
          • Wolf1977
            • Jul 2023
            • 59
            • Greece
            and why the specific transformer sir writes ta105/f
            and all the other that i can find from datasheets writes ta70;
            • Wolf1977
              • Jul 2023
              • 59
              • Greece
              ok sir thanks a lot for you said thats right
              this transformer is comatible on your opinion if the pins fits of cource
              something last
              if i canoot find transformer with the same pins can i solder on pcb with special
              wire for temperature ;
                • 31044
                try looking at TME website
                • R_J
                  • 9549
                  This transformer is ta105/F Fahrenheit which would be 40C (many have this 40c rating)
                  The HAHN transformer is ta70/C/B Celsius maximum ambient temperature 70°C, thermal class of insulation B (130°C)
                  If the pins match it should be ok.
                  There are many suppliers of this type of transformer from different manufacturers
                  • Wolf1977
                    • Jul 2023
                    • 59
                    • Greece
                    thanks a lot sir
                    so in your opinion its better to choose transformer with temperature
                    ta 40 degrees as the original or 70 degrees like this on the foto ?
                    • redwire
                      • 3910
                      What make/model is the oven?
                      The temperature spec is "maximum ambient temperature ta" in IEC 61558 but I think lower with an internal thermal cutout. I don't see a fuse for it on OP's board pic.
                      • Wolf1977
                        • Jul 2023
                        • 59
                        • Greece
                        siemens
                        so sir what do you suggest me ta 40 celsius or 70 celsius
                        if i found compatible pins with the old of cource
                        • R_J
                          • 9549
                          The original transformer was rated 40C, and that should be all that is required, but if you want to install a 70C that will be fine as well, I doubt the area for the power supply gets that hot.
                          • Wolf1977
                            • Jul 2023
                            • 59
                            • Greece
                            thanks a lot sir finaly i look for transformer with ta 40 celsius like the original and not for 70 celsius
                            because i am thinking if something go wrong as about as the temperature to break the thermal fuse of the transformer to be sure for the worst case e.g fire
                            • Wolf1977
                              • Jul 2023
                              • 59
                              • Greece
                              something last
                              in this foto it seems an other transformer for ceramic oven
                              why writes ta105°C/f
                              thats mean 105 degrees celsius or farenhait like my case ;
                              thanks a lot for your patience just i do a lot of questions to be sure for my choice
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                It's always Celsius, there are no parts rated in Fahrenheit degrees, it's a convention respected all over the world.
                                • R_J
                                  • 9549
                                  I made a error, It is 105 Celsius and the /F is likely the insulating material class F=155 Celcius
                                  I see similar transformers rated ambient temperature 40c, insulation class 105c
                                  It may be a special production as most of the Avisor transformers seem to be rated Ta70
                                  • Wolf1977
                                    • Jul 2023
                                    • 59
                                    • Greece
                                    thanks a lot sir
                                    so its a special edition of transformer that is used in this device
                                    if i use ta 70 class b probably i will have problem
                                    it seems in the internal of ceramic oven the temperature is bigger from 70 degrees celsius so probably breaks the thermal fuse that is 70 while on the original was 105
                                    do you agree with this ;
                                    • redwire
                                      • 3910
                                      Does the oven heat up the transformer? You know, when cooking moussaka.
                                      What model oven? It's the extra heat the control board sees when baking for a long time.
                                      • Wolf1977
                                        • Jul 2023
                                        • 59
                                        • Greece
                                        The ceramic hob is independent of the oven, it gets a separate power supply, but it is mounted on top, nevertheless I do not know how much it is affected
                                        • Bobby78
                                          Dead Oven Control Board, Possibly Transformer?
                                          by Bobby78
                                          Six long years ago, @tom66 helped me save my plasma TV here on BADCAPS, and it's still going strong. Fingers crossed for another win!
                                          I have a Frigidaire oven, rarely used, that I noticed was dead at some point during the summer, possibly after one of the bad storms. The light still comes on when the door is opened, so the circuit has power, but no sign of life from the LCD or the button panel. The control board part number is 318010700 and does not seem to be available any longer from any supplier, but there are companies that will repair them for $150-$200. Obviously I'd like...
                                          11-11-2020, 12:42 PM
                                        • labello
                                          Beko microwave oven dead !
                                          by labello
                                          Hi guys, how's it going?I hope you're all doing well. So a friend of mine told me that his little oven just dead, no noise like spark or something no blown up, anything just dead. I opened it and on the board control I found capacitor dead (you can see the dirty on the pcb , resistor broken and the rest of capacitor are low value. I
                                          just wanted to understand if existing the scheme for this controller board. Thank you do much for the answer
                                          02-14-2024, 04:05 AM
                                        • double_DD
                                          Transformer replacement for a dead coffee machine
                                          by double_DD
                                          Hi guys,
                                          I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                                          Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                                          If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                                          My other ideas:
                                          - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                                          - to buy...
                                          06-23-2025, 05:43 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
