Led spotlight 220-240W-50Hz max30W
  • bohaboha
    • Nov 2012
    • 1005
    • sweden
    Hi I have four spotlight only one is ok? that flashes can you help determine which lamp should I replace look at the pictures so you understand better thank you
  • bohaboha
    • Nov 2012
    • 1005
    • sweden
    Re: Led spotlight 220-240W-50Hz max30W
    is there no one who wants or is interested to help for this thread? don't know how they work probably they are divided in three blocks of 16 joints at a time. i have tested with ledtester which gives 23v for the whole board which has 54 joints. i don't manage to light a single one to get the value please if someone who knows i am very grateful
      • Jul 2011
      • 6040
      Take a better picture of the transformer data plate so I can read the entire thing the picture that you posted is not very clear to read everything
      Also take a picture of the back of the circuit board so I can what it looks like
      • bohaboha
        • Nov 2012
        • 1005
        • sweden
        Hi hope these are better. Are these powered by transformer or led drive?
          • Jul 2011
          • 6040
          What about the picture of the back of the circuit board
          • bohaboha
            • Nov 2012
            • 1005
            • sweden
            here är det,so you see it's a bit dark around the big diode it's been really hot don't know if it burned because when I cleaned it all went away but there is trace that it got really hot there you can see the difference in the next post
            • bohaboha
              • Nov 2012
              • 1005
              • sweden
              here it is cleaned
                • Jul 2011
                • 6040
                Here is two pages of the data that I could find of the ZC811C ic chip
                This ic chip one of the pin when looking at with the print so you can read the print the pin on the most left pin look like it not a good connection to the board
                You can find this ic chip on eBay
                https://www.ebay.com/itm/33312542232...Bk9SR7KYyd_0YA
                • bohaboha
                  • Nov 2012
                  • 1005
                  • sweden
                  thanks. let's see if I can fix them
                  • bohaboha
                    • Nov 2012
                    • 1005
                    • sweden
                    How can it be 2.504v for a single led lamp and 15.5v for the whole plate which has 54 led lamps
                      • 31050
                      6 in series, then the strings are in parallel
                      • bohaboha
                        • Nov 2012
                        • 1005
                        • sweden
                        ok but can you explain a bit more ?and if I want to replace a broken led bulb which how much volt should it have?
                          • 31050
                          put a meter across a working led to see the voltage drop
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Those lamps don't have sufficient cooling, look at all the dark LEDs in photo #4.
                            • bohaboha
                              • Nov 2012
                              • 1005
                              • sweden
                              as you see it gives 2,5 v and there is 54 led and i get 15.5v total how can it be?
                              • bohaboha
                                • Nov 2012
                                • 1005
                                • sweden
                                They lie on a cooling surface.but apparently it is not sufficient
                                  • Jul 2011
                                  • 6040
                                  There 9 parallel strings 6 in series @ 2.5 volt LEDs = 15.5 volts power supply voltage
                                  So if the LED driver ic chip is defective or there is an issue with the switching power supply or you have LED ic chips over current or do not light at all or very dim these are going to be most of your issues unless you have bad soldering joints
                                  • bohaboha
                                    • Nov 2012
                                    • 1005
                                    • sweden
                                    thanks very clear explanation. at the moment I'm still repairing the car I'll look at it here afterwards
                                    • vestaviascott
                                      Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                      by vestaviascott
                                      Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                      Here's what happens:
                                      1) Power on
                                      2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                      3) Blue status light flashes for appx 4 minutes...
                                      07-29-2020, 06:08 AM
                                    • AJ847.63e
                                      BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                      by AJ847.63e
                                      Hi All.
                                      Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                      The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                      09-18-2023, 06:42 PM
                                    • mikey5791
                                      Help on Samsung Syncmaster T220 dead ccfl lamp
                                      by mikey5791
                                      This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                      Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                      10-18-2020, 03:17 AM
                                    • khelane
                                      test active pfc power with lamp test
                                      by khelane
                                      Hello
                                      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                      Is there a way...
                                      06-03-2025, 01:00 AM
                                    • Yanleb
                                      Sharp LC-60LE810UN Lamp Error
                                      by Yanleb
                                      I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                      I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                      Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                      I've tried all the key...
                                      08-24-2021, 11:48 PM
