Laser CNC
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Laser CNC
    Laser CNC, board MPC6515 driver panel PAD03 V1.2. In PAD03 V1.2 quartz resonator is broken. question - to what frequency was it. I try 12MHz but not succes.
    • 31281
    Re: Laser CNC
    if you know the part number on the microcontroller then you can look up the crystal it probably uses
    so lift the sticker and see whats under it
    • R_J
      • 9623
      Re: Laser CNC
      It might be a mpc89e58, similar to a 8051, it should use a 12mHz crystal, Did you try an actual crystal or a ceramic resonator?
      • warsztat
        • Feb 2017
        • 190
        • Polska
        Re: Laser CNC
        I try 12MHz but not communication with MPC6515
        I will try another frequencies. I'm using now an 8MHz quartz resonator now, it shows the same message, but currently I don't have a communication checking machine. I will check on popular frequencies while in the company.
          • Jul 2011
          • 6070
          Re: Laser CNC
          Check and see if it has a low voltage detection ic chip because some micro controller use this type of device and it will cause it to keep trying to restart in a loop
          It would be located on the 5 volt rail near the micro controller input pin the device is normally a 3 pin device look at the data sheet for what would a low voltage detection circuit
          • corrize
            Resonator - quartz broken - how to find the same (same frequency) ?
            by corrize
            Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
            I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
            I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
            I'm searching another one for compare…
            Do you have an idea or another way for find the frequency of this resonator please ?
            (I did not found the manufacturer of this component ? And I did not found the...
            03-27-2025, 09:20 PM
          • pc_okay
            Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
            by pc_okay
            Hello friends,
            Its been a while, i wish you an happy new year 2025 !
            I have this laptop doesn't start, power light up a second when pluging USB-C charger.
            Laptop take 0.11A.
            All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
            I get no oscilation on XTAL 32.768 KHZ
            Battery is not charging but charging led is here.
            PCH heat at 30° approximatively. (with no heatsink)
            I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
            It's a 2 pins Crystal.
            01-13-2025, 09:26 AM
          • Dannyx
            Hilti PD30 Laser Range meter Error 276
            by Dannyx
            Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
            So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
            07-30-2023, 05:05 AM
          • dansity
            Power DeWalt 12V laser measure from power supply
            by dansity
            i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
            However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
            I want to power it from my PSU.
            The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
            i want to know what is the third pin exactly and what do I need...
            10-29-2023, 03:04 AM
            I would like an explanation of how a laser can measure a product on a conveyor belt
            by sam_sam_sam
            I saw this on
            “How do they do it “
            The laser was measuring the diameter and the height of the product and the weight of the product and it was a straight line laser light across the the conveyor belt ( this is all that was shown in the video clip of the laser that was used )
            What type of product is this that can do this
            I want to thank anyone that knows what of laser this is
            04-24-2022, 07:55 AM
