Identifying a Component
  • SkyHeart
    • Jul 2022
    • 11
    • Sweden
    Hi guys,
    I would be very grateful if someone can help identify the component in this picture.
    it has 4 pins one of pins gone off while removing it from the PCB, the PCB is a Motor controller for adjustable Desk.
  • petehall347
    • Jan 2015
    • 4430
    • United Kingdom
    Re: Identifying a Component
    looks like its a rectifier
    • R_J
      • 9579
      SMD bridge rectifier, looks like diotec S80
      • redwire
        • 3912
        My guess is a DB-S SMT bridge rectifier, like a DB103S is 200PIV. It's about 8x6.2mm. The S80 is smaller 4.7x3.9mm. You'd have to measure the part size.
        • SkyHeart
          • Jul 2022
          • 11
          • Sweden
          Thanks for the help guys, it does look like S80 SMD bridge which I did order some from mouser.com
          • juergenb
            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
            by juergenb
            i am asking for some Help.
            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
            The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
            So i got a few of these from Banggood.
            I swapped the motor and now i have a new fault condition.
            In a working Frother you would press the start button, it will light red and work for a few minutes.
            If you press longer it will light blue and just mixup the milk.
            With the new Motor it just starts...
            03-23-2021, 11:24 AM
          • sbt123
            charnwood w821 mini wood lathe motor problem
            by sbt123
            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
            10-27-2024, 03:43 AM
          • corrize
            Where to find a very small fpc connector 0.3mm between 2 pins ?
            by corrize
            Hello, I search this connector (oxydated).
            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
            Do you know how to find this connector please ? What is the exact name for find it ?
            08-06-2024, 05:25 PM
          • RolandVossen
            Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
            by RolandVossen
            I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is...
            03-16-2024, 03:55 AM
          • mikey5791
            Help identify this motor
            by mikey5791
            Hi all forum members,
            Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
            Correct me if i am wrong on the initial test.
            Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
            11-24-2023, 07:54 PM
