Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
  • RolandVossen
    • May 2023
    • 11
    • Nederland
    I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is mounted on top of the dial.
    I measured the resistance using a DVM over the 3-pins connector, and did not get consistent results. I also measured directly over the potmeter, that gave consistent and expected results. Thus I suspect some sort of connection problem. However. The dial PCB is painted, so the underlying pcb traces are not visible. I am unsure if the 3 leads of the potmeter should simply route to the 3 pins of the 3-pin connector, or if there is perhaps an active component (eg a diode or transistor) in-between.
    I turned my attention to the motor controller PCB and thought: what if I connect a potmeter to the 3-pin terminal (CN107), would the machine then work properly. But: I had no pin-out of that connector on the motor controller PCB.
    I contacted Kenwood Europe for schematics and got denied, response was that if they'd share schematics, they'd be liable for accidents. I wonder if that is a viable reasoning. I then escalated to sustainability@delonghigroup.com but so far got radio silence.
    I proceeded to reverse-engineer part of the motor controller PCB in order to discover the 3-pin terminal assignments (CN107). See attached image in which I used an image editor (Gimp) to overlay the component side of the PCB onto the solder side. Perhaps it is useful for another soul in the future.
    My question would be: can anyone confirm that the potmeter 'dial' is a simple 1:1 connection to the 3-pin cable/connector emerging from the dial ?
    Thanks, Roland.
  • GraphicMan
    Kenwood K266 kitchen machine
    by GraphicMan
    Device works randomly for 1 sec for every 20 trial
    so it is not really dead
    by removing the relay top and pushing its mechanism the motor works normally but ofcourse while bypassing the speed control
    I am not sure if the relay was the issue or something else
    I have a question, how this relay works when I cant see any 24vdc supply
    on the pcb to power it
    hope to hear from you guys
    here is video for how i bypassed the relay
    https://www.youtube.com/watch?v=nKZg_bcCrR8...
    03-15-2023, 01:43 PM
  • DrDos
    Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
    by DrDos
    Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
    08-08-2025, 03:16 AM
  • Mark R
    The Overseas Only Kenwood Model KR 790
    by Mark R
    I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
    The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
    09-23-2025, 08:27 PM
  • DrDos
    kenwood kr-6030 Mosfets?????
    by DrDos
    Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
    09-20-2025, 04:42 PM
  • phuzzyday
    Sony 70" 70X690E - It's now a divorce risk! (6 Months on kitchen table.) New power board installed! STILL trouble!?!?
    by phuzzyday
    For masochists who want to see some of the crap that I have been through already... (Truly optional now though, all those trees were barked up for no reason.)
    https://www.badcaps.net/forum/troubl...klight-circuit
    I started a new thread to get a fresher look at things, even with eyes that looked before. It's different now!
    So I got this on Facebook for $66US, blank screen. Just reseated all...
    09-08-2025, 05:53 PM
