Garmin dog training collar.ID help with SMD, Please?
  • Macroman
    • Feb 2022
    • 22
    • USA/Philippines
    Re: ID help with SMD, Please?
    Continuing with the garmin collars...Here is another TT10 everything working except shock and tone. I'm posting this also hoping that it may help others with these issues.
    Replaced the GPS module and collar will connect with handheld Alpha100 and able to track but the shock and tone functions are still not working.
    I found 4 components (capacitors) that are reading short to ground (marked with red marker), 1 on one side the board near the SN9B019 chip (multi-voltage power controller) and 3 more capacitors on the other side of the board.
    I see no cracks in the inductors on this board, like is seen on the other boards.
    Yet the same issue with the shock and tone functions..???????? Hmmmmm????
    • Macroman
      • Feb 2022
      • 22
      • USA/Philippines
      Re: Garmin dog training collar.ID help with SMD, Please?
      Did some further trouble shooting and found that the 0402 component that the arrow is pointing to in the image below is shorted on all the units that I have tested so far.
      Replacing it with good ones from donor boards fixes the issue of the non-working tone/shock function of the collars.
      Also...some of the collars with cracked inductors work after replacing the 0402 component.
        • 31003
        looks like a resistor or inductor.
        meter a good one.
        • Macroman
          • Feb 2022
          • 22
          • USA/Philippines
          meter a good one.
          okay..thanks!
          I plan on metering one today.
          I hope to learn the value of the component, then maybe purchase replacement smd..it will help my friend to save a lot. New collar is $300 USD each.
          • UserAlexandr
            • Sep 2022
            • 8
            • Ukraine
            The inductors are damaged. This is the hull design.
            There is not enough space between the battery and the board.
            When used and any strikes are damaged.
            • UserAlexandr
              • Sep 2022
              • 8
              • Ukraine
              #26
              Originally posted by macroman
              did some further trouble shooting and found that the 0402 component that the arrow is pointing to in the image below is shorted on all the units that i have tested so far.
              resistor 1Ω
              • UserAlexandr
                • Sep 2022
                • 8
                • Ukraine
                #27
                [QUOTE=Macroman;1162737]Continuing with the garmin collars...Here is another TT10 everything working except shock and tone. I'm posting this also hoping that it may help others with these issues.
                3 capacitors according to the scheme are in parallel with the inductors. they will be read to the ground. You don't need to be here. This part of the circuit is responsible for the emission of the radio signal.
                Update the collar firmware via WebUpdater
                • UserAlexandr
                  • Sep 2022
                  • 8
                  • Ukraine
                  #28
                  The TT10 collar is the most unfortunate of the entire line. Can only work with Alpha 100.
                  He thinks his firmware for a very long time. He slows down. Do not torture the components on the board! Most likely they are correct.
                  If the main components fail, the device does not turn on!
                  Update firmware. Change ID in settings. Check if the feature is enabled.
                  Go outside and wait for satellites and communications on the collar and Alpha 100.
                  Check.
                  Does not work? Track the circuit from the output of the function.
                  • Macroman
                    • Feb 2022
                    • 22
                    • USA/Philippines
                    #29
                    Check.
                    Thank you very much!!..
                    I have found NPN transistor that is not giving correct reading when tested.
                    • Macroman
                      • Feb 2022
                      • 22
                      • USA/Philippines
                      #30
                      Did some more testing with multimeter in diode mode and found that there is a BJT-NPN transistor on the board that is not testing correctly..
                      The attached image shows the readings I recorded and the placement of the red and black leads during the testing.
                      • UserAlexandr
                        • Sep 2022
                        • 8
                        • Ukraine
                        #31
                        Have you looked at the datasheet for the transistor? Have you disconnected the transistor from the electronic board? There are no exact measurements on the electronic board in the circuit. For an accurate determination, separate the part from the electronic board. Use a device such as the ESR LCR-T4 tester on the Atmega328.
                        Is the component installed near the audio speaker? On a 3.3 Volt power circuit? If there is a beep when turned on, do not touch it. He is a worker.
                        • Macroman
                          • Feb 2022
                          • 22
                          • USA/Philippines
                          #32
                          Thanks..
                          I did remove it from the board and test out of circuit. I tested with LCR-T7 ESR meter...Readings were...
                          BJT-NPN
                          hFe=207
                          Ube=698mV
                          Ic=5.9mA
                          There is no audio, except for beep tone when turning unit on and off.
                          It has 3.7V input power
                          Data sheet:
                          https://cdn.badcaps-static.com/pdfs/...be5f171f21.pdf
                          • zeko542
                            • Mar 2023
                            • turkey
                            #33
                            hello friends I just joined you I have a request from you I need garmin t5, tt15, dc50 and tt10 mainboard schematics
                            • zeko542
                              • Mar 2023
                              • turkey
                              #34
                              Is there anyone who can help with this
                              • UserAlexandr
                                • Sep 2022
                                • 8
                                • Ukraine
                                #35
                                Garmin has protected their products well. Schematics for these devices are not freely available. Repair of devices is possible without service manuals.
                                • MicroSMD Lab
                                  • Sep 2018
                                  • 139
                                  • Trinidad and Tobago
                                  #36
                                  Thanks to the OP for starting this thread. I have replaced GPS antennas on some of these, mostly TT15. I also repaired some of the LNAs and a few boards with liquid damage. Working without schematics is a real pain.
                                  UserAlexandr seems to be very familiar with these units, I hope you will share more of your experiences with us.
                                  Almost all of them I worked on had the same coil cracked but it does not affect the functions, I guess that's why the EMF shield has a piece of neoprene on it.
                                  The 1ohm resistor referenced to previously is connected to GND so it's not a short. If the functions worked after replacing it, most likely heating up the board in that area caused something to work.
                                  Currently I'm working on one that is not powering up, there's a 30ohm short on the input/ vcc to the SN9B019. Nothing is heating up with 2.5V/ 2.5A, only drawing about 70mA, I compared with a known good board and the resistance should be in the Mohm range.
                                  • Mardelplata
                                    • Jul 2023
                                    • argentina
                                    #37
                                    Hello, do you have any news about breakdowns on the Tt10 and TT15? thanks
