Garmin dog training collar.ID help with SMD, Please?
Re: Garmin dog training collar.ID help with SMD, Please?
Thanks to the OP for starting this thread. I have replaced GPS antennas on some of these, mostly TT15. I also repaired some of the LNAs and a few boards with liquid damage. Working without schematics is a real pain.
UserAlexandr seems to be very familiar with these units, I hope you will share more of your experiences with us.
Almost all of them I worked on had the same coil cracked but it does not affect the functions, I guess that's why the EMF shield has a piece of neoprene on it.
The 1ohm resistor referenced to previously is connected to GND so it's not a short. If the functions worked after replacing it, most likely heating up the board in that area caused something to work.
Currently I'm working on one that is not powering up, there's a 30ohm short on the input/ vcc to the SN9B019. Nothing is heating up with 2.5V/ 2.5A, only drawing about 70mA, I compared with a known good board and the resistance should be in the Mohm range.Leave a comment:
hello friends I just joined you I have a request from you I need garmin t5, tt15, dc50 and tt10 mainboard schematicsLeave a comment:
Have you looked at the datasheet for the transistor? Have you disconnected the transistor from the electronic board? There are no exact measurements on the electronic board in the circuit. For an accurate determination, separate the part from the electronic board. Use a device such as the ESR LCR-T4 tester on the Atmega328.
Is the component installed near the audio speaker? On a 3.3 Volt power circuit? If there is a beep when turned on, do not touch it. He is a worker.
I did remove it from the board and test out of circuit. I tested with LCR-T7 ESR meter...Readings were...
BJT-NPN
hFe=207
Ube=698mV
Ic=5.9mA
There is no audio, except for beep tone when turning unit on and off.
It has 3.7V input power
Data sheet:
https://cdn.badcaps-static.com/pdfs/...be5f171f21.pdfLeave a comment:
Is the component installed near the audio speaker? On a 3.3 Volt power circuit? If there is a beep when turned on, do not touch it. He is a worker.Leave a comment:
Did some more testing with multimeter in diode mode and found that there is a BJT-NPN transistor on the board that is not testing correctly..
The attached image shows the readings I recorded and the placement of the red and black leads during the testing.
The TT10 collar is the most unfortunate of the entire line. Can only work with Alpha 100.
He thinks his firmware for a very long time. He slows down. Do not torture the components on the board! Most likely they are correct.
If the main components fail, the device does not turn on!
Update firmware. Change ID in settings. Check if the feature is enabled.
Go outside and wait for satellites and communications on the collar and Alpha 100.
Check.
Does not work? Track the circuit from the output of the function.
I have found NPN transistor that is not giving correct reading when tested.Leave a comment:
Check.
Does not work? Track the circuit from the output of the function.Leave a comment:
Re: ID help with SMD, Please?
[QUOTE=Macroman;1162737]Continuing with the garmin collars...Here is another TT10 everything working except shock and tone. I'm posting this also hoping that it may help others with these issues.
Replaced the GPS module and collar will connect with handheld Alpha100 and able to track but the shock and tone functions are still not working.
I found 4 components (capacitors) that are reading short to ground (marked with red marker), 1 on one side the board near the SN9B019 chip (multi-voltage power controller) and 3 more capacitors on the other side of the board.
I see no cracks in the inductors on this board, like is seen on the other boards.
Yet the same issue with the shock and tone functions..????????Hmmmmm????
3 capacitors according to the scheme are in parallel with the inductors. they will be read to the ground. You don't need to be here. This part of the circuit is responsible for the emission of the radio signal.
Update the collar firmware via WebUpdaterLeave a comment:
did some further trouble shooting and found that the 0402 component that the arrow is pointing to in the image below is shorted on all the units that i have tested so far.
Replacing it with good ones from donor boards fixes the issue of the non-working tone/shock function of the collars.
Also...some of the collars with cracked inductors work after replacing the 0402 component.
The inductors are damaged. This is the hull design.
There is not enough space between the battery and the board.
When used and any strikes are damaged.Leave a comment:
okay..thanks!
I plan on metering one today.
I hope to learn the value of the component, then maybe purchase replacement smd..it will help my friend to save a lot. New collar is $300 USD each.Leave a comment:
looks like a resistor or inductor.
meter a good one.Leave a comment:
Did some further trouble shooting and found that the 0402 component that the arrow is pointing to in the image below is shorted on all the units that I have tested so far.
DC50, T5? Damaged inductors on all Garmin collars. Occurs when the shield cover is struck or closed. This is their disease. In this state, they work and the collar turns on. SN9B019 This is a multi-voltage power controller.
If you want to replace the throttle, then take it from a donor or measure a serviceable one.
If your collar does not turn on, then the coil is not the problem.
This is a TT10 collar...I have looked at several of these for my friend (TT10's, TT15's, and a couple T5's) and a lot of them have the same problem with the inductors for sure.
Do you think that this is being caused from a "jar" while the dog is wearing the collar??... Or could it be that the guys are tossing the collars around roughly..say into a metal toolbox or storage compartment on a dog box, etc.????Leave a comment:
If your collar does not turn on, then the coil is not the problem.Leave a comment:
you could lift and meter an undamaged coil - if you have an LCR or component testerLeave a comment:
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by Use2bavolvocan someone please help elaborate if a bad cap will affect time / clock functions. My fancy coffee machine has a preset pour for espressos's all of the presets are way out of wack what use to be 25 seconds is now 12.
I am about to replace the psu caps but need some guidance if a bad cap would slow down or speed up clock functions?-
Channel: General Capacitor Questions & Issues
by ducati82Hi everyone.
I have a Garmin TT15 mini GPS collar with radio power problems. The handheld detects it up to a distance of about 50 meters and then loses it until it gets closer again.
I tried replacing the RF amplifier but the problem remained.
What could I check? I don't know much about RF.
If you need other information, just ask.
Thanks in advance...1 Photo -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
- Loading...
