Garmin TT15 gps dog collar
  • ducati82
    • Jun 2024
    • 7
    • Italy
    Hi everyone.
    I have a Garmin TT15 mini GPS collar with radio power problems. The handheld detects it up to a distance of about 50 meters and then loses it until it gets closer again.
    I tried replacing the RF amplifier but the problem remained.
    What could I check? I don't know much about RF.
    If you need other information, just ask.
    Thanks in advance
  • harp
    • Jun 2022
    • 642
    • Planet Earth
    Have you see this tread
    https://www.badcaps.net/forum/troubl...ith-smd-please
    Maybe some usefull information inside...
    • ducati82
      • Jun 2024
      • 7
      • Italy
      Hi harp, I had already seen that topic but unfortunately the problems are different and it didn't help me 😪
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        I would check first how much RF this little thing is making. Maybe it's not the transmitter, could be that your receiver is deaf some reason or maybe there is something wrong with the antennas on either side. If An antenna has high SWR let’s say 3:1, then most of the power the rf amp makes gets reflected back to it and never makes it out the antenna.
        I am not sure what distance this Garmin should be able to transmit, but I guarantee you it’s much more than 50m. More likely something like 5 - 10km depending on range line of sight and hills in between and antennas used.
        For me it sounds like you got antenna issues somewhere.
        • petehall347
          • Jan 2015
          • 4440
          looks dubious Click image for larger version
Name:	Screenshot from 2024-06-17 11-31-15.png
            • Jul 2011
            • 6070
            looks dubious Click image for larger version  Name:	Screenshot from 2024-06-17 11-31-15.png Views:	0 Size:	105.6 KB ID:	3291898
            What is the component that was in that soldering joint huh interesting picture
            I would check every soldering joint for quality of the soldering joint when you see something like this
            • ducati82
              • Jun 2024
              • 7
              • Italy
              I have another collar that works perfectly with that handheld (I tested it up to 5km)
              • ducati82
                • Jun 2024
                • 7
                • Italy
                Is a photo problem, the soldering is perfect and in any case it concerns the GPS and not the RF circuit
                • harp
                  • Jun 2022
                  • 642
                  • Planet Earth
                  Are they the same model, maybe you can compare measurements one with other...
                  • petehall347
                    • Jan 2015
                    • 4440
                    looks like it connects to gps to me
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      Then something is either open or shorted to ground on the RF circuit. Here would be a RF probe handy…
                      • ducati82
                        • Jun 2024
                        • 7
                        • Italy
                        Yes, same model
                        • harp
                          • Jun 2022
                          • 642
                          • Planet Earth
                          That is ok, but I also dont know much about RF, and interested in about learning basic rf troubleshooting principes.
                          What will I do while master come to help, is that replace antenas from working unit to faulty one and see if this change anything...
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8340
                            I would replace that VHF antenna with a 1/4 wave wire antenna and bench test it from home for starters. To me it sounds like there is no VHF antenna hooked up.
                            • Macroman
                              Garmin dog training collar.ID help with SMD, Please?
                              by Macroman
                              I have several boards like this from my buddy...The boards are out of training collars for hunting dogs. Powered by 3.6V Li-ion, 2750mAh, 9.9Wh battery. This components are related to the audible tone and shock functions of these collars... and all have these same SMD components that are bad. All the boards have 2 of these (as shown in the 2nd image) and the related functions of the units are non-working on the boards with the damaged SMD's. They have only C on them.
                              Does anyone here know how to find out what this component is and where to get it.. if it is available??
                              08-18-2022, 03:20 PM
                            • Adubey
                              Garmin Dashcam 20
                              by Adubey
                              Hi All, I have a Garmin Dashcam 20. It allows functions to work only if SD card is inserted but it freezes upon inserting a working SD card. So far I have cleaned the SD card socket with alcohol and all of the connections looks good. I also tried using a brand new class 10 SD card as its manual requires but still its not working. Garmin Express is also not able to detect the device.
                              I am able to get into menus using a bad SD card.
                              Let me know if anyone has ideas on what to do.
                              10-02-2023, 05:29 PM
                            • spleenharvester
                              Reverse engineering of DoCreate DHJ567 handheld spot welder
                              by spleenharvester
                              Hello everyone
                              I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                              Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                              05-08-2025, 02:52 PM
                            • laidman
                              Yamaha psr ew400 piano loses sound
                              by laidman
                              Yamaha PSR EW400 piano intermittently loses sound and shuts down.
                              Youtube people recommend verifying that the DC jack's solder connections aren't broken, and the replacement of a couple of capacitors in the vicinity of the DC jack. While these solutions might work, I'd feel a lot more secure if I had a schematic to help me check the status of the myriad components.
                              Schematic and suggestions are welcome.
                              11-18-2023, 05:13 PM
                            • etnpc
                              ROG Ally Handheld RC71L BIOS Password
                              by etnpc
                              Hi there! This went out on rent and came back with a BIOS password. I don't want to throw it away and would be happy to donate for assistance. The label is as follows:
                              RC71L-ALLY.Z1_512
                              SN: R9NVKD020696367
                              CN: 7H45
                              Any help is absolutely appreciated!
                              02-14-2025, 07:24 AM
