I am not sure if this is the right forum to ask this question or not but I will ask it anyway and take my chances. I plugged my Canon Power Shot Camera into a 9 volt dc power supply and of course the camera is rated for 3.15 volts, I wouldn't even try to explain why I did this but now my camera will not work, will not turn on and the lens is stuck out? I think my SD card is fried as will? It do not show up in my card reader? The questions are; what possible damage did I do to my Camera? Is it repairable? Where do I go for help? Is it possible to download a repair manual for this camera?
Canon Power Shot A540
Re: Canon Power Shot A540
Can't say for sure. Worst case scenario is one of the ICs died from the over-voltage. Best case is only if a fuse blew or a zener diode shorted.Originally posted by davgThe questions are; what possible damage did I do to my Camera?
Hard to say. Have you tried giving it proper voltage supply to see if it powers on (other than from the batteries)? If you have a multimeter, see if there's a short between ground and positive.Originally posted by davgIs it repairable?
Other than that, you'll probably have to open the camera and look for shorted components. Basically look for a fuse or a diode near the input jack.
Tried looking on Google? I doubt anyone here will have a repair manual for this particular camera (certainly hope I'm wrong, though).Originally posted by davgIs it possible to download a repair manual for this camera? -
Thanks Momaka appreciate your reply. The only thing I tried was to add fresh batteries but no go. I have not tried opening it up but looks as though I may have to? I have searched the web for a service manual but can't seem to find one.Comment
hi davg i did the same thing to my canon a540 today, connected a 12 volt supply in place of 3 volt and my camera died also SD card no longer works. i got few repair manuals of different models on elektrotanya but could not locate the fuse in this model. i am curious if you were able to get ur camera working, just curious to know the fix.Comment
chances are high it fried more than just a fuse. (especially because you say the SD card is also dead)
fuses are usually labelled as Fxxx on the boards.
some examples of what they could look like
http://www.google.com/search?q=smd%2...UTF-8&tbm=isch
With a multimeter, check resistance between power supply input and ground. If you get a short circuit or open circuit, there may be some chances of saving it.
Also, if you have the camera already opened, take some pictures of the circuit board(s) and post them here.Comment
In better news, a new motherboard for this camera should be straight-forward to find on the likes of eBay if it is fried.
Word of advice though - there is a high capacity cap inside the camera which may still be charged: DON'T get shocked by it, it bloody hurts and may also cause you to drop the remainder of the camera on the floor. Ask me how I know!?
Chris...Comment
multimeter reads 2 ohms between positive and negative.
i could not locate anything saying fuse on the motherboard,
i found a slightly big smd with 2 terminals named 33 62rnj with a diode kind of marking, i assumed it is a zener and removed it but no go, but the resistance is still the same b/w positive and negative.
even i am of opinion something more than a fuse or zener is fried as SD card is fried and sd card holder is on a diff board not main motherboardComment
Well I still think it's worth a try - the camera is not working anyways so you can't really lose anything else except for time. Your call on that.
If you decide you want to troubleshoot it further, just keep removing components connected between positive and negative until you eliminate the short. It may be a ceramic cap, and it may be a small voltage regulator or transistor. One easier way to find it, or at least narrow down what it could be is to briefly apply 1v to 2v between positive and negative, preferably with a 1A or more rated power supply. See which component gets hot and remove it, them measure resistance.Comment
thanks momaka for your suggestion, there is logic in what u say, lemme try that.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by joaquinmjuanHello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...05-07-2025, 12:26 AM
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
