BAUN - UVST - 0617,Can anybody Identify these Please?
    replied
    Re: BAUN - UVST - 0617,Can anybody Identify these Please?
    tp4054 on aliexpress
    you get 10 for a $
  • Ritchie_Uk
    replied
    Hi R_J
    You are correct, the CON3 is the internal Battery
    I will look for a replacement, and see if I have any on old Laptops
    Its been an uphill struggle ans Manufacturers and component suppliers really Wont or dont Help, so the folk sin this Group have really helped go in the right direction
    Will Keep you updated
    Stay Safe
    Originally posted by R_J
    The TP4054 is a sot23-5, just look at the datasheet, the XX4054 seems to be made by may companies with a slightly different part number
    After a closer look at the picture in post #10, I see CON3 is the battery connector, so this must be the correct ic.
  • Ritchie_Uk
    replied
    Aah Ok let me look
  • R_J
    replied
    Originally posted by Ritchie_Uk
    I think this might be the Manufacturer
    http://www.hjc-ic.com/en
    They are a distributer not a manufacturer. Just pick your favorite parts supplier and order one.
  • Ritchie_Uk
    replied
  • R_J
    replied
    Noppa - Would you happen to know what SOT it is please?
    I know it’s cheap, and the moment I collected it, it wasn’t worth the repair, but it’s for a friend.
    I love problem solving
    Thanks again..
  • Ritchie_Uk
    replied
    Hi Petehall
    Sorry, I missed your post
    what is the black socket on the right for ? u1 looks like it may connect to it
  • Ritchie_Uk
    replied
    I know it's cheap, and the moment I collected it, it wasn't worth the repair, but it's for a friend.
    Thanks again..
    Hey Noppa -Thank-you
    I can't wait to check in a few hours, as it's late now
  • Ritchie_Uk
    replied
  • Ritchie_Uk
    replied
    Hey R_J I need to re-check in a few hours, so I don't give you false information.
    I will attempt to draw out a basic schematic.
    Here is a photo of the MicrOne version, the logo and markings are different, but I suspect the operation will be the same.
    I asked if you traced out the pins to see if this is the same ic, For example, pin 3 seems to connect to CON3, is this where the battery connects???
  • noppa
    replied
    from here
    https://www.s-manuals.com/smd/54
    found this
    https://cdn.badcaps-static.com/pdfs/...27c931373b.pdf
  • R_J
    replied
  • Ritchie_Uk
    replied
    Here
  • Ritchie_Uk
    replied
    Hi Folks - Just got back
    Thanks for your responses
    The component companies haven’t got a clue what it could be
    This is the product
    https://www.whathifi.com/news/aldi-r...able-just-ps30
    replied
    is it related to a lithium battery?
    ME4054?
    http://www.microne.com.cn/ProductDetail.aspx?id=100
  • petehall347
    replied
  • Ritchie_Uk
    replied
    His TJ
    Great detective work.
    What do you think the component is?
    replied
    logo looks close
  • Ritchie_Uk
    replied
    Thankyou
    I have emailed a couple of component suppliers, to see if they can sell me equivalents.
    I will keep you updated.
  • R_J
    replied
    Then is likely has to do with charging the battery, trace out the circuit as I can't tell where the traces connect to based on the picture.
    There are lithium battery charge ic's like the Tp4054, this may be similar made by some odd manufacture
    The TP4054 might be close, check the datasheet and see if the pins line up. It looks close from what I can see.
  • thesame
    DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
    by thesame
    Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
    The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
    02-27-2024, 04:31 AM
  • silver60618
    Lenovo Legion 7 - Help Identify IC
    by silver60618
    Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
    I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
    Any help would be appreciated...
    07-02-2025, 12:16 PM
  • chth96
    How can I identify varistor which have been blew up?
    by chth96
    I mistakely pluged 100v japanese retro game console to 220v outlet.
    So It seems that glass fuse and varistor have been blew up.
    I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
    Is there any way to identify varistor type in my sega saturn PSU?
    Any reply would be appreciated.
    EDIT:
    It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
    11-26-2023, 08:52 AM
  • freakorio
    Need Help To Identify Component on Ymain LJ41-05120A
    by freakorio
    Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
    05-21-2024, 02:32 AM
  • baiceanu_stefan
    nm-f251 Schematic, boardview or help identify componente
    by baiceanu_stefan
    Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
    04-24-2024, 12:49 AM
