Log periodic antenna to Coaxial cable... balun right?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8710
    I acquired a (large) used rooftop log periodic broadcast reception antenna and it didn't come with wiring. I figure I could use it for parts if nothing else but first I'd like to see if this thing actually works for receiving distant stations.
    From passing from amateur knowledge, these log periodic antennas need to be matched to the impedance of coaxial cable, nevermind the balanced nature to the unbalanced nature of co-ax. So I'll need to locate a balun.
    So I was wondering about people who worked on rooftop terrestrial broadcast antennas...are these log periodic "dipole" typically 300Ω and I'll need to get a 4:1 balun to attach to 75Ω co-ax? Should I feed twin lead 300Ω down to the house and have the balun inside the house or is it just like transmitting antennas where it's best to have these matching networks close to the feed point?
    I just so happen to have a 4:1 300Ω to 75Ω balun but it's not sealed for outdoor use, so would be best to keep it indoors or perhaps take it in when it rains...
  • CapLeaker
    Leaking Member
    • 8352
    Re: Log periodic antenna to Coaxial cable... balun right?
    Not all log periodics are 300 Ohms. Kind of really need to know what it is. Let’s say it has a 300 Ohm feed point. You could use 300 twin lead and run it inside under the roof, then use that 4:1 balun and run coax to wherever you want to.
    • R_J
      • 9625
      One of these should work
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8710
        hmmm what are typical log periodic impedances?
        I need to look for a large pipe or something I can use as a mast, and wonder how high I need to have it to exceed performance of indoor rabbit ears... Roof mount would be best but not for now...
        • CapLeaker
          Leaking Member
          • 8352
          The most typical is 300 Ohm for those TV antennas, unless there is a tuning stub or something. If there isn’t any matching mechanism, it plain 300 Ohm. Now if you use twin lead 300 ohm cable, it has less losses an works over a wider frequency range vs coax. As soon as you put that balun in there and go coax, you have more losses.
          Coax advantage: 75 Ohm, unbalanced, shielded, can be laid anywhere. Disadvantage: higher losses.
          Twin lead advantage: 300 ohm, balanced, works over a very wide frequency range, less losses. Disadvantage: unshielded, cannot be laid in metal pipe, or touch metal etc. It needs holders of some sort.
          Years ago, I put an antenna like that in my barn roof. Look around, people are giving away old TV towers.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8710
            Due to the HOA and the government provision to not deny me outdoor OTA antennas, but towers are a no-no. This antenna I picked up is fairly large, so I wonder how well it performs though as a log periodic, it's not a yagi...
            I never thought of running it in my roof alas I don't think this is an option. My roof access hole is like 2x2 and this antenna is like 10 feet long, 4 ft high, and 8 feet wide... have to do some serious disassembly to get it into the roof...
            • hiperco
              Vizio M492i-B2 with periodic lines on the screen
              by hiperco
              Having an issue with periodic lines on the screen. Any suggestions on which board(s) to blame first? Video below
              VIDEO
              Link to another post with pictures of boards etc
              02-19-2023, 12:16 PM
            • eccerr0r
              Cheapest waterproof RF coaxial connector?
              by eccerr0r
              What would be the cheapest weatherproof RF coaxial connector one could get?
              Searching for "cheapest waterproof RF coaxial connector" gives me F-connectors. F-that. Not 50 ohm. Next seems to be the N-connector, which I don't have any around. I suspect both still should be capped to keep dust and other debris out.
              I suspect most hams would use an NMO mount on their cars to pass signals to the roof, but I want something that I could salvage cheap. Having it survive 75MPH+ "wind" is another story but that's a different problem to solve.
              05-09-2021, 01:27 PM
            • TrblShtr
              SPDIF Coaxial Output & Toslink Input Clarification
              by TrblShtr
              Hey all hope everyone is staying safe out there! I have a quick question regarding SPDIF cable input/output connectors & audio quality. Is there such a thing as a digital cable with one end being digital optical (Toslink) and the other end being digital coaxial? The reason I ask is because my PC motherboard has both coaxial and optical outputs but my speaker system only has a digital optical input which is what I'm using at the moment (aware toslink max audio quality is up to 96Khz). My motherboard can provide audio up to 192Khz which is what I would like to achieve for maximum audio quality...
              02-16-2021, 04:29 AM
            • TheDandy
              Samsung UN40ES6100 backlight periodic flashing
              by TheDandy
              This set's got a backlight that comes on, dims, and switches off periodically. Picture's fine, but the backlight cycles between on and off. All my research seems to point to the BN44-00502A power board, and a buzzing can be heard near the top of the board when the backlight goes off.
              Visually inspecting the board, all the caps seem fine and there's no leakage, though there is a lot of residue from the factory on the back. Near the top of the board under some diodes there is some discoloration, but it appears to be present on every example of this board I can find including pristine...
              08-30-2020, 04:32 PM
            • Hondaman
              Single-channel antenna?
              by Hondaman
              Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
              I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
              Years ago I made a "T"...
              11-18-2024, 01:14 AM
