Cheapest waterproof RF coaxial connector?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    What would be the cheapest weatherproof RF coaxial connector one could get?
    Searching for "cheapest waterproof RF coaxial connector" gives me F-connectors. F-that. Not 50 ohm. Next seems to be the N-connector, which I don't have any around. I suspect both still should be capped to keep dust and other debris out.
    I suspect most hams would use an NMO mount on their cars to pass signals to the roof, but I want something that I could salvage cheap. Having it survive 75MPH+ "wind" is another story but that's a different problem to solve.
    • 31259
    Re: Cheapest waterproof RF coaxial connector?
    F are not 50ohm, they have no center, it's down to the cable
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      I suppose it should be clear, need female chassis connector...
      • tester272001
        • 91
        Slather on some liquid electrical tape. that stuff is GREAT. or heat shrink around the entire thing ? Where are you trying to connect at the antenna feed point?
        • redwire
          • Dec 2010
          • 3912
          You have a drip-loop so water (rain) doesn't flow into the connector, from along the coax.
          I've used waterproof heatshrink tubing, which is a bit thicker jacket and full of hot glue, it shrinks and squishes the hot glue. But not great for high flex. And you have to make sure wind etc. won't direct water inside.
          3M has many specialty "rubber" electrician's tapes, self-fusing silicone rubber tapes that are great, this is what you would use at the tower.
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • 5mall5nail5
            Help identifying connector for ASUS 4090 Strix RGB LED connector
            by 5mall5nail5
            Hi All -
            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
            05-04-2025, 07:47 AM
          • bussincaps
            MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
            by bussincaps
            Hello All,
            tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
            Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
            eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
            Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
            I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
            08-03-2023, 12:57 PM
          • michhak
            Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
            by michhak
            Hi guys,
            i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
            It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
            11-17-2021, 05:45 AM
          • m1ch43lzm
            70mai Dash Cam A510 - help identifying connector on camera module
            by m1ch43lzm
            Hi everyone
            I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
            The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
            I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
            05-11-2025, 06:02 PM
