Vizio M492i-B2 with periodic lines on the screen
  • hiperco
    • Feb 2015
    • 6
    Having an issue with periodic lines on the screen. Any suggestions on which board(s) to blame first? Video below
    VIDEO
    Link to another post with pictures of boards etc
  • nomoresonys
    • 12330
    • U.S.
    Re: Vizio M492i-B2 with periodic lines on the screen
    try re-seating and cleaning tcon cables, can use ipa alcohol, some use a pencil eraser, not too vigorously they can be delicate.
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • jeyoung12
      Samsung QN50Q60t lines on screen
      by jeyoung12
      Hi all
      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
      So....i don't know what end of the C ribbon to work with...
      02-26-2024, 10:38 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • kdaniel
      Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
      by kdaniel
      As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
      There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
      After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
      Left...
      11-16-2022, 09:23 AM
    • Chrissygizmo
      Sony KD-55XG9505 lines on screen problem
      by Chrissygizmo
      Hello again everyone,
      This is my latest mission, to try getting this Sony tv back to normal working order…
      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
      02-19-2025, 11:31 AM
