LED Array Schematic Check?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Was wondering if someone would double-check my design here. It's relatively simple. I used an online LED array calculator to get the core array specs. And for the potentiometer, I figured that since the sum of the parallel resistors (since I don't know the internal resistance of the LEDs) is 5.5 Ohms, that adding a 5 ohm pot for dimming would be sufficient, if not overkill possibly.
    Each LED is rated at 3.2V 150ma
    VCC = 19V from a laptop power supply, so it should be a fairly stable source voltage.
    I need the thing to be stable and to be able to dim it. Does this design seem like it would fit that requirement?
    And here is the PCB layout, front and back....
    sigpic
    • Jul 2011
    • 6058
    Re: LED Array Schematic Check?
    You could also use a PWM controller to dim the LEDs I have done this in the past you might need to use a filtering capacitor on the output so you do not see the switching of the PWM controller ( these controllers are very inexpensive to buy )
    Because I also am going to use a LED yard light with a PWM controller to set to a certain brightness to save on battery power and not use a resistor to control them
    Another option is use a switching power supply that can be adjustable voltage output I have a couple of them and they work pretty good and they are the same size as a laptop charger
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      You mean use something like this?
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Lets say if I went with PWM for the source, and I wanted to add an RC filter to smooth out the PWM as in this schematic ... since the circuit is calculated to consume 11 watts, would that resistor (R5) need to be a 15 Watt resistor?
        sigpic
        • diif
          • Feb 2014
          • 6978
          • England
          You don't get flicker with those PWM controllers. I have the identical ones but bought from Ali at about the third of the price.
            • Jul 2011
            • 6058
            Note you would not need R5 if used the PWM controller if you did it correctly you might need not need R1 to R4 you need to do some testing on the PWM controller that you use and see if those resistors are not need or you might less resistance values than what you have on your diagram now
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              I ordered one and got it today. Ive got some circuit boards from a past project configured in almost the same array, I can jurry rig it to be the same ... so ill be able to test the exact configuration.
              No resistors at all, hu? That sounds risky.
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                So this is the unit I got, but when I connect power to it and turn it on, the led lights up but no voltage on the output. I verified the LED array is working with my bench power supply but this thing isn't doing shit.
                sigpic
                  • Jul 2011
                  • 6058
                  Are you sure that you do not have it hooked up backwards because I have done this myself before
                  I see that this board is marked the ones I have are not marked very well so it is to hook them up backwards
                  Yes this should work just make sure that you have a current meter hookup so that you do not over drive the LED array unless you want to change the brightness then you have a little bit more work to do then you need to find out what the resistance is on the pot ones you have reached the maximum current or less than the maximum current and that is allowed for the LED array then put a resistor on the top end of pot so that when the pot is maxed out this your maximum current you want to have on this LED array
                  I hope this helps you with what you want to do
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Definitely had it hooked up properly ... I decided to tap all of the solder points that I could reach with my iron, and I got it to show me a voltage that was about ¾ of a volt lower than what the bench power supply was feeding it ... so if I gave it 12 volts, it would read about 11.25-ish on the output... but as soon as I hooked up the LEDs, i got nothin. So I decided to put the scope on it, and I got nothin that was useful in terms of a signal but the volt meter would read a voltage from the output but as soon as I connected the LEDs, I could get them to work VERY DIM when I cranked up the power supply to 30 volts feeding the PWM ...
                    Anyways ... it was basically a bust all around ... I decided to just order another one, assuming got a bad apple from the bunch ... and they're only like $6 ... people pay $15 for a pack of cigarettes these days ... no idea how people can afford to smoke. lol
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      So I got the new unit today from Amazon, and it worked right out of the gate ... and surprisingly it works quite well in spite of the fact that when I connect it to the scope, the signal is dirty as all hell. That was the first thing I connected it to and looking at that shitty signal I did not expect it to work at all ... but ... it does ... and amazingly well so I'll be using this for sure as the dimmer for my circuit. Though I'm leaving the series resistors in the circuit ... certainly can't hurt ... but I won't be using the resistor/pot that I originally asked about.
                      sigpic
                        • Jul 2011
                        • 6058
                        See if you add a small value capacitor to the output make the power supply output cleaner and smoother
                        I have used this approach for a dc volt solenoid amplifier controller that I used to control a solenoid valve with a PWM controller because the machine controller went partially bad and I still need the machine to keep working with a partially malfunction machine controller
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          Well, I already ordered the circuit board, but as luck would have it, I mirrored the VIN ports cause I wasn't sure which side of the board would make the most sense once I retro-fit the dimmer into the light enclosure... so whichever ports I don't use, will be perfect for a cap.
                          sigpic
                            • Jul 2011
                            • 6058
                            Let us know how this works and if you can post a picture of it when it is finished
                            Oh by the way what is this made for
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              I'd be happy to do that... what fun are projects if you can't show em off?
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                Here is a pic of the final circuit board installed:
                                Should be obvious now what its for... it is replacing the stock circuit board on this lamp that I'v grown rather fond of over the years.
                                The PWM device is being fed 19 volts but only 17 are reaching the circuit at max volume ... I put a 1k uF cap on it for now cause that's what I had in the immediate vicinity... not impressed with the brightness but at only 17 volts that explains why. I think the PWM device has its own voltage drop that is possibly consuming that 2 volts so i gotta find a way to feed it like 21 volts or something so ˆ*can get 19 at the output.
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  So I realized my thinking was all wrong on the voltage issue... I didn't need to give it more voltage, I needed to give it less resistance. So I ran the numbers for a 17V source and the resistor value came back at 6.7-ish ... all I had in an SMD package was a 7 ohm ... PERFECT! So I replaced the resistors with the 7Ohm and the light is much brighter now and surprisingly does not put out a lot of heat which I am just elated about that. At max volume, you couldn't hold onto the LEDs for very long, but certainly not burning hot and at ½ to ¾ volume, they hardly get warm with plenty of usable light.
                                  And here are photos looking through the magnifying glass, without the light on and then with the light on at full blast ... but the photos don't really do it justice.
                                  sigpic
                                    • Jul 2011
                                    • 6058
                                    Nice work
                                    I need to need to redo a fluorescent magnifying glass that is to heavy for the flex rod which is not long enough to begin with and use LED lights instead but I am not very good designing circuit boards
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      The brightness should assist in depth of field in the camera - if it supports it.
                                      Sigh. Unfortunately most cameras do not these days as it'd increase their thickness...
                                      I'm still using fluorescent bulbs in my magnifier lamp and probably won't stop until they can't be had easily anymore. Though I should figure out why it seems to be sputtering filament onto the ends so quickly. I suppose it's a problem with running these tubes CC with its electronic ballast.
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        I am NOT a fan of fluorescent light on any level ... I even replaced my kitchen lights with those LED tubes that they sell... I had to bypass the ballast entirely as the LED tubes only accept direct 110 but that was an easy thing to do and the light that they provide is AMAZING ... hands down superior to the fluorescent bulbs.
                                        sigpic
                                        • Gadjet
                                          Need Schematic for RCF EVOX J8 two way array
                                          by Gadjet
                                          need Schematic for RCF EVOX J8 two way array
                                          10-01-2023, 12:15 PM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • atunguyd
                                          Acer x163w Monitor PSU schematic
                                          by atunguyd
                                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                          03-05-2025, 02:08 PM
                                        • dreico33
                                          TL866 II Plus Check ID Error on various IC
                                          by dreico33
                                          Hellow guys , i really need your help here.
                                          Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                                          11-04-2024, 03:13 PM
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
