LED Array Schematic Check?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: LED Array Schematic Check?
    Nothing wrong with fluorescent tubes, I don't mind them at all. A lot easier to service than LED, then again the hope is that LEDs never fail. But look at all those TVs...
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Right? And even this lamp that I bought lasted all of 8 months before the LEDs in it started flickering out and I had to replace them ... after the third time replacing them and it started in with its flickering crap again, I had enough of it and decided to make this board which ... I expect ... will last a lot longer since the design seems more stable to me than what it shipped with ... and so far I only run the lamp at 50% on the dial until I need to use the magnifying glass then I crank it up to 100% but the lamp stays on all the time ... just at 50% in between actual use of the lamp.
      I never have found a fluorescent magnifying lamp that could produce the lumens that I can get with LEDs.
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        I have a generic question that maybe one of you can answer ...
        Consider the original question I had where I talked about using a potentiometer as the brightness adjuster for this circuit ... based on the calcs I was seeing, when I was going to use straight DC voltage for this circuit, I would have had to use a pretty fat POT as the brightness adjuster since it appeared that quite a lot of current would be running through that pot....
        Given that PWM is technically more efficient than using straight voltage ... what would the results be of implementing an RC filter at the output of a PWM source? Then adding a pot at that point for brightness adjustment? Would it bring it back to the original problem where the current would be such that the pot would have to be more robust or would the fact that the source voltage is simply filtered PWM mean that the calcs should be different given that the source is different than a straight DC source?
        This question is purely academic by the way ... I'm just curious.
        sigpic
          • Jul 2011
          • 6058
          Depending on how the PWM signal is generated it might make a difference but I am not sure exactly because when I had to do this for an industrial application the PWM was generated by a micro controller and with type of signal this is very noisy environment and putting a small value capacitor on the output cleaned it up enough that the device worked correctly this is what I am going by but when I look at the volt meter with out the capacitor on the output you could see the voltage fluctuation with your eyes but after putting the capacitor on the output it smooth out the voltage fluctuation and was less notable
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            Which reminds me ... I need to look at the output of this PWM dimmer with the cap on it with the scope ... curious to see what it looks like.
            Here are some screenshots of the scope when I had the PWM dimmer connected to 19 volts then the output was connected directly to the scope (not under load at all).
            If I'm not mistaken, the phantom traces in that third image, which are clearly distinguishable from the real signal ... is a result of the scope being unable to lock onto the signal thoroughly because the signal is so crappy in the first place.
            sigpic
            • Gadjet
              Need Schematic for RCF EVOX J8 two way array
              by Gadjet
              need Schematic for RCF EVOX J8 two way array
              10-01-2023, 12:15 PM
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • atunguyd
              Acer x163w Monitor PSU schematic
              by atunguyd
              Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
              The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
              03-05-2025, 02:08 PM
            • dreico33
              TL866 II Plus Check ID Error on various IC
              by dreico33
              Hellow guys , i really need your help here.
              Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
              11-04-2024, 03:13 PM
            • hasel17
              CH341a can erase and read but can't write and blank check
              by hasel17
              So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
              Code:
              Checking for blank...
              (Press
              10-26-2023, 06:20 AM
