Has anyone had issues with Rayovac Alkaline batteries leaking
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    #101
    Re: Has anyone had issues with Rayovac Alkaline batteries leaking
    Originally posted by stj
    aliexpress.us???
    thats not the links.
    use a pc or a better browser
    Aliexpress.us is the new website for people using AliExpress in the USA. I tried the link on a PC (Windows 11, both Chromium Edge and Firefox), and got the same result.
      • Jul 2011
      • 6057
      Just post the seller name and I search for them thanks
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        for me, these links also do not seem to work and thus 404s... hope aliexpress isn't cracking down on linktrack cleanup
          • 31137
          well copy the item number from each link and past it into the ali search box
          • m1ch43lzm
            Replacing 2xAA / 2xAAA alkaline batteries with Li-Ion / LiPo battery?
            by m1ch43lzm
            Hi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
            I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
            I'm open to suggestions on whether i should use an LDO or another type of voltage...
            05-27-2025, 05:34 PM
          • howardc64
            Where do repair shops buy MB replacement batteries?
            by howardc64
            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
            07-25-2024, 10:42 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • dbuergi
            DIY: Modified smart charger for all types of batteries
            by dbuergi
            sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
            Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
            My first work was to bring my Samsung watch battery back to life with was not recognized...
            07-18-2025, 03:17 AM
