Ubiquiti US-16-150 Help
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Got this dead Unifi US-16-150W, assuming it was the power supply. Alas the PSU and everything looks perfect and the PSU is outputting a solid 53V.
    I noticed that upon disconnecting then reconnecting the 4-pin connector from the PSU to the switch's mainboard it makes quite a spark. More than I would expect. So I got curious, took the mainboard out, and found the bottom to be like this.
    Is this water damage? Or something else? Should I try to clean it off? Or is it toast?
    • Jul 2011
    • 6039
    Re: Liquid damage or somethign else?
    Try cleaning up with denatured alcohol and see if you can clean or use a good flux remover spray I have clean a few boards with a flux remover spray
    https://www.mpja.com/Flux-Remover-41...info/30364+MG/
    It might be water stains but I not completely sure about this
      • 31014
      thats residue from water soluable flux,
      the factory isnt changing the water often enough.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Gotcha, thanks, do you think there is any point in cleaning it? Or is something else wrong with it?
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: Ubiquiti US-16-150 Help
          Alright, so I did a little testing.
          I've attached a couple pictures. I have a solid 24V across the purple caps. This is probably the circuit for the 24V Passive PoE function.
          More important, in the other pic across the two points right below the pink dot I have fluctuating 0 to 3.3V. I'm assuming this is a/the problem.
          What can I check to see why the 3.3V is fluctuating like that?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Most likely something is shorted and the power supply is hiccuping: that is it senses the short, powers down and then tries again...
            Some times such a short can be found by a thermal camera (or hand) or you can use a very sensitive multimeter in ohms mode.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Hmm, thing is the power supply is happily at 53.7V with absolutely no fluctuating the entire time.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                I mean on the secondary side, the 3.3v power supply.
                • CapLeaker
                  Leaking Member
                  • 8146
                  Probably there are no shorts on the 3.3V rail. I think there is something else that gets powered from the 3.3V rail that shorts out when powered up. Check the other buck converters. Power the 3.3V up with a bench power supply and see what happens...
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Hmm, OK, I'll have to rig something up.
                    In the meantime, I found this bubble on one of the BCM59111KMLG chips. It's supposedly a 60W PoE controller. Is this normal? Or bubbles=bad?
                    • CapLeaker
                      Leaking Member
                      • 8146
                      That chip is the problem I’d say.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        That chip is the problem I'd say.
                        Thank you, I will see what I can do. I wonder if it's going to be really hard to remove lol.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          It's dead Jim. That's a burn mark alright. Look also at the discoloration on the PCB around it.
                          Speaking of removal, depending on the power of your hot air station, you may need to use some sort of preheater or hotplate, that chip is a QFN with a large heat dissipation pad underneath.
                          A working TV? How boring!
                          • CapLeaker
                            Leaking Member
                            • 8146
                            Shouldn’t be that hard to remove. You can always preheat the board, then take it off with hot air gun.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              It's easy peasy if you preheat, just don't be surprised if a cheapo chinese SMD rework station alone won't cut it.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                it better be good enough because that's what i ordered haha. i will update once i've tried it.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  so, i got my cheapo smd rework station and it worked perfectly to remove the chip.
                                  i was hoping i'd get at least some sign of life now that the chip is removed and presumably the short is too.
                                  unfortunately its still dead. what can i check now :'(
                                    • 31014
                                    check for shorted ceramic caps near the dead chip area.
                                    • CapLeaker
                                      Leaking Member
                                      • 8146
                                      Check your wonky power rail. See what it does now?
                                        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                        by sam_sam_sam
                                        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                        04-09-2023, 08:04 PM
                                      • edugimeno
                                        Stagg sms12p audio amp has water damage
                                        by edugimeno
                                        Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                        I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                        There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                        There is only one signal wire connecting the first boards...
                                        05-24-2025, 06:00 AM
                                      • shovenose
                                        Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                                        by shovenose
                                        Got this one for free because, well, it no worky.
                                        A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                                        Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                                        08-11-2021, 01:26 PM
                                      • RetroComputingGrotto
                                        Water Damaged Toshiba 48L1435DB
                                        by RetroComputingGrotto
                                        I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                                        The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                                        10-07-2024, 08:23 AM
                                      • rzsn
                                        water damaged G513I
                                        by rzsn
                                        Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
                                        Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
                                        12-22-2024, 09:02 PM
