Zener diodes component equivalents
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
    1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
    2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
    3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
    These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: component equivalents
    Yes.
      • 31259
      Re: Zener diodes component equivalents
      what country is SG?
      i can find a seller of smd diodes probably
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Originally posted by stj
        what country is SG?
        im in Malaysia
        • DjKrish
          • Oct 2012
          • 354
          • SG
          1. UDZSTE-1710B (9.99V 200mW) (SC-90, SOD-323F)
          corrected
            • 31259
            so asian region - aliexpress should be a good source.
            or LCSC.
              • 31259
              https://www.aliexpress.com/item/1005002257063237.html
              • DjKrish
                • Oct 2012
                • 354
                • SG
                or LCSC.
                aliexpress will take more than a month ive ordered from element14
                  • 31259
                  they dont have the 10day option to malaysia??
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    Sadly no
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • dazzystar
                      Samsung BN44-00517C PSU...identifying these zener diodes
                      by dazzystar
                      Does anyone know what value these zener diodes are please on a Samsung BN44-00517C PSU board?
                      01-13-2024, 03:28 AM
                    • Fritter
                      Pioneer VSX 531.Sourcing zener diodes
                      by Fritter
                      Pioneer VSX 531
                      I have a zener - ZJ4v3b - to replace on a pioneer AV amp. Closest replacement I can find is NZX4v3b (I think!)
                      I can only find them at RS and in quantities of 200.
                      Wondered if anyone can guide me to another replacement or a supplier that doesn't require a 200 lot order ?
                      Many thanks.
                      07-31-2023, 09:23 AM
                    • Instafixx
                      Macbook A2179 820-01958
                      by Instafixx
                      Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                      The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                      I checked the Power Sequences below and found this -
                      Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                      PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                      PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                      05-20-2023, 05:19 AM
