Pioneer VSX 531.Sourcing zener diodes
  • Fritter
    • Jun 2023
    • 21
    • England
    Pioneer VSX 531
    I have a zener - ZJ4v3b - to replace on a pioneer AV amp. Closest replacement I can find is NZX4v3b (I think!)
    I can only find them at RS and in quantities of 200.
    Wondered if anyone can guide me to another replacement or a supplier that doesn't require a 200 lot order ?
    Many thanks.
  • petehall347
    • Jan 2015
    • 4451
    Re: Sourcing zener diodes
    mouser but expensive your numbers dont work at rs but do at farnell
    • Fritter
      • Jun 2023
      • 21
      • England
      Farnell had a 6 week lead time for a minimum 1000 order IIRC. The ZJ code is the original component.
      • Fritter
        • Jun 2023
        • 21
        • England
        You're correct about the RS code. The component I think will be a replacement is TZX4v3B. Just checked the basket that has been there for three days
        • petehall347
          • Jan 2015
          • 4451
          would a 5 percent C version be close enough ? can buy them in twenties at rs .
          • Fritter
            • Jun 2023
            • 21
            • England
            Re: Pioneer VSX 531.Sourcing zener diodes
            I'm not sure. The 5 channels are all using the same component and they're very small, although there is room on the board.
            • petehall347
              • Jan 2015
              • 4451
              i suppose you could get 20 and see if you can select one that's closest to 4.3v without knowing the circuit and what the 4.3v is for i cant start to guess .
              • Dvsr
                On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                by Dvsr
                Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                After replacing the caps I started testing out the speaker. It seemed...
                09-10-2025, 10:20 AM
              • caspian
                What Zener Diodes on a Linear Power Supply
                by caspian
                Dear members,
                I have a linear variable power supply with unknown brand name that I used for voltage injection.
                Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                In addition, I discovered that its zener diodes are defective.
                I can replace the burned transistors.
                But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                Therefore, I cannot replace the zener diodes.
                I do not want to test the zener diodes in a test circuit to discover their model or value.
                no schematics are available...
                05-26-2025, 12:38 PM
              • Nikolai Danylchyk
                Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                by Nikolai Danylchyk
                Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                Thanks in advance!...
                05-08-2025, 06:18 AM
              • DjKrish
                Zener diodes component equivalents
                by DjKrish
                Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
                1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
                2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
                3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
                These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
                08-15-2021, 11:06 PM
              • dazzystar
                Samsung BN44-00517C PSU...identifying these zener diodes
                by dazzystar
                Does anyone know what value these zener diodes are please on a Samsung BN44-00517C PSU board?
                01-13-2024, 03:28 AM
