Permanently Retired Systems:
Kooky and Kool Systems
No. Most likely the blade is going to have only one shaft insert on one side, unless I get really lucky and the hole indeed goes from one side to the other, which I've rarely seen.
No, it's most likely similar to the one shown in post #16, hence why I think all I have to do is flip the rotor around. A shaded pole motor would be too big to fit in a fan like this.
I don't have one of my exact fan, but when I pulled out its impeller because it seemed a bit wobbly and I tried balancing it a bit better, I had a look behind it and I can confirm it looks just like the one in post #16.
Okay, then remove the two screws holding the bearing retainers and reassemble with the stator flipped.
The leads will exit opposite their usual place, check for mechanical interference.
It's most certainly a shaded pole motor.
When you have it apart, you'll see the heavy copper shunt bars, which is what makes them self-starting without multiple windings & a run cap or centrifugal switch.
Woodgears just shows a larger, C-frame one (that powers a gearbox).
Incidentally, those shading shunts are what limit these motors to some awful efficiency, something on the order of 30 percent.
They then exist, after the motor's at speed, as shorted turns!
"pokemon go... to hell!"
EOL it...
All style and no substance.
guilty,guilty,guilty,guilty! guilty of being cheap-made!
