Desk ESR meter
  • Shodan486
    • Nov 2009
    • 203
    Desk ESR meter
    Just wanna ask one thing: Are such devices like in the link able to measure precisely (or at all) correct values from the caps soldered onto the motherboard, so called in-circuit measurement?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2759.l1259
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • Shodan486
    • Nov 2009
    • 203
    Re: Desk ESR meter
    Problem solved - it can't, close the thread!!!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Desk ESR meter
      its sometimes tricky to test in circuit.
      caps in paralel with others or mlcc's can fool you.
      • Shodan486
        • Nov 2009
        • 203
        Re: Desk ESR meter
        I'm really thinking about this one : http://cgi.ebay.com/Peak-ESR-70-Mete...item1c10015a82
        • Bobdee
          • Jun 2008
          • 461
          Re: Desk ESR meter
          Try this link
          http://www.peakelec.co.uk/acatalog/jz_esr70.html
          You get the warranty with it too
          I have the ESR60
          But as kc has said there is a lot of caps that wont give readings in circuit
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: Desk ESR meter
            the dick smith "blue" is well proven too.
            • chth96
              by chth96
              03-09-2024, 10:03 PM
              12-31-2023, 06:04 AM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
              12-14-2023, 07:45 PM
            • Stephan Mathers
              EDMI ATLAS MK10 Electronic Meter Discussion
              by Stephan Mathers
              Greetings, new guy here but always interested in the crazy universe of modding
              We just finished construction of around 25 vacation houses, all inside the same private area.
              Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
              The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
              Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
              05-20-2025, 09:09 AM
