Theory behind "sometime works, sometime doesn't"
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    Today I watched a YT video about Macbook repair, posted by Paul Daniels. I enjoy watching repair videos in general, but this particular draw my attention. If you see part: https://youtu.be/KwwI62NGBSc?list=PL...tbkvew1c&t=356 around 5:55, where he found a corrosion around crystal,
    he said it explained such behavior.
    I'd like to understand how corrosion around crystal can cause laptop to work sometime and some other time doesn't work.
    I've readsomething similar but about electrolytic caps. If they are too old and lose capacity or have ESR increased, this can also cause similar behavior.
    Can you please, how this is possible, what is the theory that explains it?
    I know that someone can be a very successful repair guy if without understanding the details oftheory behind it, but I'd surely like to understand why is that. The thing is that I had few problems lately that sometimes work and sometimes don't.
    Than you!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Theory behind "sometime works, sometime doesn't"
    I know that a bad solder joint can cause that type of symptom.
    Had that with an old Bearcat scanner. (the power input connector had a bad solder joint)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Askic
      • Sep 2018
      • 187
      • BIH
      Yes, that is perfectly understandable. With bad solder joint, as device gets heated or change working temperature, there are heat dilatations that can cause a break in connection. Perhaps the same applies to corroded parts, I don't know if the joint solders can corrode.
        • 31283
        crystals are a special case - you always want the area around them perfectly clean.
        any capacitance between the pins or from the pins to anything else - even a long track with nothing on it will cause the frequency to change or even stop it oscillating.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5086
          • New Zealand
          Keep watching to 7:38... the track was broken at the test pad due to corrosion.
          -David VanHorn
          • CapLeaker
            Dell ATX PSU won’t start, but forcing it works fine?
            by CapLeaker
            Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
            Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
            10-28-2024, 06:59 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ex250
            Kenwood SW-505D no sound issue and pops from time to time when it works
            by ex250
            Hello mates,
            I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
            It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
            12-29-2024, 03:27 PM
          • eurowill
            a2141 820-01700 internal display not working / external works
            by eurowill
            Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
            Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
            07-23-2024, 10:06 AM
          • vf fa
            EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
            by vf fa
            Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
            I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
            So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
            01-31-2024, 01:40 PM
