Magneto voltage limiter
  • Pierre95
    • Feb 2016
    • 65
    • France
    I recently had some ride on my old moped. After a few miles the front light-bulb burned-out. This is typical issue with those unregulated AC magneto outputs. The bulb is designed for 6V.
    Some mopeds are equiped with 2 Zener diodes limiting the output voltage from the magneto.
    As both front and rear lights connect directly to the magneto, adding zener diodes would globally limit the AC voltage, which I don't want because the magneto also supplies voltage to indicator lights circuit and horn buzzer and both work better with higher voltages value.
    I am thus wondering how to design an AC limiter which takes variable AC voltage with variable frequency as input and produce variable same frequency output but with fixed AC amplitude and of course minimum power loss.
    Any idea about it?
    Thanks.
  • Pierre95
    • Feb 2016
    • 65
    • France
    Re: Magneto voltage limiter
    Sorry could a moderator please move the thread to General Electronics Technical Discussion, seems more appropriate.
    • petehall347
      • Jan 2015
      • 4425
      • United Kingdom
      properly wired in zener diodes should be fine
        • 30951
        convert the lights to led based.
        they dont care about the voltage because you regulate the current.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8680
          back to back zener diodes is an AC limiter and should work as you need but it's an immense power waste.
          If you really want no power waste you need to go through a lot of circuitry -
          1. Convert AC to DC (easy enough, bridge rectifier and capacitor)
          2. Switch mode power supply to get a constant DC voltage (lots of components)
          3. convert DC back to AC (lots of components).
          This might be more trouble than it's worth. Converting from incandescent to LED lamps with a bridge rectifier and a linear regulator may be cheaper in the long run even if you have to have multiple, one for each bulb.
          • redwire
            • 3900
            If the magneto is generating 9V, the zener clamps to 6V, wasting the excess as heat. Do you have a battery? It would boil and lose water.
            You don't want to use a zener because it shunts excess voltage and just loads the motor down, as well as getting hot.
            There are 6V magneto voltage regulators you can buy or make. The Kubota circuit is better than the other popular circuit - that shorts out the magneto. Then people wonder why the coils are burnt.
            I would mod the Kubota regulator for 6V. The circuit is from the 1970's though.
            edit: the large voltage drop of the bridge rectifier and SCR's (~2V) might cause the lights to be way dimmer at idle or low speeds. Might have to use Schottky diodes and something better than two SCR's.
              • Jul 2011
              • 6027
              Let me ask a stupid question here ——>
              why not regulate the the voltage at the light bulb sockets ( or the wiring to the sockets) and let everything else stay the same scene the problem you are having is with the light bulbs burning out
                • 30951
                a lot of regulators wont like voltage dips.
                • redwire
                  • 3900
                  Any (series) regulator will lose some voltage (or dropout), so dimmer lighting at idle or low speeds.
                  Any (parallel) shunt regulator wastes the extra voltage as heat, with the motor loaded down more and it just wastes energy.
                  You need an AC LDO, connected like this dual LM317 circuit I remember. I'd guess it loses almost 3V though. LT1084 would work but a real LDO (pair) would only lose maybe 0.3V if you picked out a good IC.
                  This dual Darlington accomplished about the same thing, if you mod it for 6V output.
                  Not sure how many watts OP's lighting load is.
                  • petehall347
                    • Jan 2015
                    • 4425
                    • United Kingdom
                    has it not got separate coils in the mag ? i seem to remember one for lights and other one for battery charging . you could try next highest voltage/wattage bulbs .
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8680
                      need OP to reply but usually magneto means no field coil, and without a field coil, the need for a battery is gone... Since everything is AC, it'd make it more difficult to also power with DC from a battery, and thus I'd say engine off = no lights because no battery ...
                      Phase control dimming/regulation is a solution I didn't think of at first, it might be the only low loss solution without doing the whole conversion process or just using LEDs and eating the loss.
                      • petehall347
                        • Jan 2015
                        • 4425
                        • United Kingdom
                        indicators and horn will be dc .
                        • Pierre95
                          • Feb 2016
                          • 65
                          • France
                          Thanks to all of you.
                          Firstly, there is no battery at all, only the unregulated magneto output. As the stock version is missing indicators, I already designed a regulator circuit driving an astable multivibrator tuned to approximately 1Hz for the blinking to take effect.
                          Indicator lights are LED, which helps saving power for front/rear lights and the horn.
                          Each element (Front light, rear light, indicators, horn) takes the power from one wire, the other being moped's frame. This prevents usage of full wave rectifiers, as they create another ground reference separated from the chassis.
                          Other constraint: the lamp holders I bought for the indicators connect such a way it is the anode of the LEDs that receives the frame which leads to creating a negative DC voltage, in order to drive the cathode.
                          Yes, that's precisely what I don't want: shorting the Magneto output through Zeners as it will have lot of negative effects.
                          Thanks for the schematics redwire, I will have deeper look
                          It actually has: one is for ignition, the other for lights and horn.
                          Sorry, the horn is not a buzzer. It requires AC current in order to make the membrane vibrate.
                          Both front and rear lamps are 6W.
                          This is exactly what I would like to achieve. I am not against creating another DC voltage from Magneto's AC output. However, don't know how to implement full wave rectification which keeps the same ground reference (moped's frame). This is why I was thinking of AC to AC regulation.
                            • 30951
                            if you use leds - this may interest you.
                            you can use them in parallel for higher currents too.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8680
                              Localized DC regulation is probably your best bet. The grounding/return wire you'll have to isolate it from your own "ground."
                              LEDs are good because they inherently use less power, so you can waste a bit and still have original brightness. Trick is to get it as small as possible.
                              You could still use the back to back zeners but put the zeners in parallel with the LED chain and have the dropping resistor pass current to the LEDs also pass through the zeners. That way the magneto won't see the shunting, it will still see the series resistor. You could put raw LEDs in the fixture with the zeners and ensure you have the dropping resistor outside the lamp fixture.
                              Because of the localized grounding your options are limited as you have to stick stuff inside the lamp housing, unless you're willing to drill some holes or something to set up your own isolated wiring system.
                              • Pierre95
                                • Feb 2016
                                • 65
                                • France
                                After a few weeks of involvement on other tasks, I tried designing my own AC limiter.
                                Top wave form shows an amplitude modulated sine wave which is representative of the variable output AC voltage from the magneto. The signal changes from 0 to almost 50V peak to peak. The output signal (bottom) never goes above ON Zener + ON diode voltage (6,8V+0,7V). The zener and diodes maintain the voltage on the base so that when the voltage on emitter goes above the limit the transistor starts acting as a resistor which forms a voltage divider with R2 (=the lamps)
                                This is only a "working principle" schematics as enough powerfull transistors will have to be selected, to dissipate the extra power.
                                This has the advantage of only doubling the dissipated power each time input voltage doubles.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8680
                                  Thanks for following up, it looks like you got a solution that may well work (no guarantees, simulation doesn't always equal real life!). Go for it, though I still prefer LED retrofits
                                  You still will need to deal with dropout voltage, though I don't know what your typical voltage is (which depends on RPM of course and that changes...) and couple that with your minimum required brightness.
                                  The only thing I'm a bit concerned about is the reverse breakdown and long term reliability. But that's another issue...
                                    • 30951
                                    another option, rectify the ac, run it into a bank of caps and then feed it through a regulator into led lamps.
                                    the caps will smooth any dips or flickering.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8680
                                      Would need a huge capacitor if he's insisting on incandescent which seems to be the case... but yeah another benefit for retrofitting LED's, you can do stuff like this...or heck even have a switching converter and have perfect fuel efficiency running headlamps and still have constant brightness regardless of engine speed...
                                        • 30951
                                        and add a digital speedo!
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
                                        • electron_jj
                                          Panasonic TH-L42D25A checking the PSU output voltage
                                          by electron_jj
                                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                          08-29-2021, 08:13 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          by sam_sam_sam
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
