Identifying electronic component
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello experts,
    do you have any idea what are the components labeled with letter V on PCB?
    I cannot measure resistance with the multimeter (it's probably very high). There is a picture in the attachment. These elements have some kind of protective function. One side is connected to the ground.
    Thank you in advance.
    • 31286
    Re: Identifying electronic component
    they are probably some form of zener diode
    • R_J
      • 9625
      Can you post a large picture of the component? 455x134 is too small to make out the logo. is it C? 9CA I suspect they are tvs components
      • Askic
        • Sep 2018
        • 187
        • BIH
        Thanks for the feedback.
        This is the best picture I can do, because the components are tiny.
        It is written CM 9CA and the logo is very much like Toyota.
        This is the analog input card of the PLC (receives thermocouples). These are the first elements that have connection to the thermocouple in the field. When there is an overvoltage they usually go short to the ground.
          • 31286
          bi-directional TVS diode - probably 9v
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            My thinking, too. The logo looks like that of General Semiconductor (a division of Vishay).
            PeteS in CA
            • R_J
              • 9625
              I think they are Vishay bi-directional Transzorb SMBJ33A (CM) I suspect the 9CA could be date/mfg code
              The ones marked MM are directional type. Here is the same part with a different date code
              • Askic
                • Sep 2018
                • 187
                • BIH
                Thank you very much for the information. I couldn't test it with multimeter set to test diodes and therefore I was confused. Now, from the datasheet I can see that the applied voltage must be higher in order the diode to start conducting.
                  • 31286
                  that's how it works, when the voltage rises above the level safe for the circuit, the diode turns on and shorts the voltage to ground.
                  • Askic
                    • Sep 2018
                    • 187
                    • BIH
                    Hello guys,
                    can you please help me identify components show in the attached picture?
                    I have found that component nr. 1 is tantalum capacitor, most likely 33 uF, 16V
                    https://cdn.badcaps-static.com/pdfs/...88116449c7.pdf from manufacturer Vishay.
                    However, I'm not sure what components 2 and 3 are. They are most likely produced by Vishay and they some kind of Zener or TVS diodes, but I'm not sure if this 25A means 25 amperes. It sound a lot to me.
                    I hope you'll be able to help me.
                    Thank you very much.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Yes, they are TVS diodes.
                      • Askic
                        • Sep 2018
                        • 187
                        • BIH
                        Thank you!
