Akai Inverter transistor ID
  • HenryJ
    • Oct 2006
    • 54
    LCD tv Mod# LCT3285TA
    Thanks Henryj
  • HenryJ
    • Oct 2006
    • 54
    Re: Akai Inverter transistor ID
    Ok so i still can't post pics so # on them are D413, D454
    • PlainBill
      • Feb 2009
      • 7034
      When you are entering your message scroll down to Additional Options and click on Manage Attachments to add photos.
      PlainBill
      • HenryJ
        • Oct 2006
        • 54
        Found Thanks Harvey
        • HenryJ
          • Oct 2006
          • 54
          PlainBill
          Thanks: PlainBill don't recall seeing this when i needed cap id that i could not post sometime ago.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5008
            • New Zealand
            That logo is Alpha and Omega semiconductors
            I think you have http://www.aosmd.com/web/products/pr...tnumber=AOD454
            and http://www.aosmd.com/web/products/pr...tnumber=AOD413
            -David VanHorn
            • x_orange90_x
              by x_orange90_x
              01-29-2025, 09:24 PM
            • valvashon
              Insignia NS-LCD19-09 (PS OK, Inverter problem?)
              by valvashon
              For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
              History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
              01-04-2024, 01:44 PM
            • eccerr0r
              A modified sine wave inverter + a grid tie inverter?
              by eccerr0r
              If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
              Next thing is trying to charge the batteries using solar power, but that's another issue ...
              08-31-2023, 09:14 PM
            • caseyjay_48
              Sony KDL-46BX450 Inverter Troubleshoot Logic
              by caseyjay_48
              I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
              I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
              09-23-2022, 08:08 PM
            • magneh
              Behringer Eurolive B205D repair - help identifying transistor
              by magneh
              Hello
              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
              Still, I need to replace this transistor....
              06-18-2025, 02:34 AM
