Re: Help identify a Zener?
Thank you so much for this schematic, this will go a long way for me to figure out my garage door even if it's not the same. Looks like it too has a bad cap in these units. But anyway the schematic exposes quite a bit of information for me.
But it looks like D104 - if that's the unit that's having problem - appears to be a generic diode and you can replace it with anything. Looks like you have a 1N4001 or something like that, it should be fine... is it working?
Agreed that the LED itself may be damaged now, quite possibly as a result for D104 shorting, so watch for that.
Also it seems that there are no zeners on the board. D107 is the only zener in the schematic, and it looks like the PCB was designed for it, but not silkscreened on the front. It looks like there's a spot for it where "D104" is printed but there's no marking for the true D107. If you want to put in a 6V zener you can, and it might save you from it zapping again and having to fix it again in the future.
here is the front and back of the EMITTER
14LG47S-2C
I put a temporary DIODE in ther,e the original was shorted. This was flashover lightning/strike.Last edited by tester272001; 09-18-2020, 03:45 PM.Leave a comment:
Post pics of the board. I did schematics for a couple generations of Liftmaster/Chamberlain/Sears garage door sensors. It's a 150Hz pulse train of 38kHz bursts from an LM2903.
It's usually the IR receiver module that fails in cold weather.
Original is TSOP1238 and I've heard a TSOP33338 works for a replacement.
D106 is a 1N4148.
Liftmaster 14LG472-2B, 14LG472-1B, 14LG372-1B; did not finish a 14SR472-1B schematic.Leave a comment:
Agreed. Is likely the LED. I see there are 2 primary LIGHT frequencies for IR leds (unless I can find a marking on teh IR LED) so I need to either try both wavelengths or see which one the IR receiver uses. it is a TPMS5380 receiver (38khz). I did have to replace a 6.2V zener on the supply so I wanted to check this one for proper voltage.Leave a comment:
this is from an Emitter board of a garage door safety sensor. The IR led seems a little dim. It is proprietary by Liftmaster. No exact schematic around and of course no parts list. I cannot seem to cross reference this part. Even knowing it is National it seems TI does not provide any backward lookup for diodes, mainly I see other active components. If you have any TIPS I all all ears! thanks!Leave a comment:
seems to be a custom part number, what/where did it come out of?Leave a comment:
Bud, thanks for the feedback! N makes sense! I've seen the test procedure before and I can try that. But I suspect this device as bad. So measuring the voltage might not give me the voltage it is SUPPOSE to be but the defective one. That is why I wanted to lookup the device. Maybe now that I know is National Semiconductor I can look it up! THANKS!Leave a comment:
That is not 'Z', the the 'N' logo of National Semiconductor.
https://en.wikipedia.org/wiki/National_Semiconductor
You can find out if it is 5V Zener or not by connecting 470 Ohms resistor in series with the Zener in question then connected them to 9V battery in reverse bias then just use Volt meter to check the Voltage on the Zener in question.Leave a comment:
Tags: None
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by hobostoveHey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
There's a 22ohm resistor that's melted and open, but it still has the bands.
The other part is a zener diode and it's top went to jesus, so I can't read the marking.
It looks like the diode connects the source and drain of a TNY284... -
by nev1001Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
I think an issue could be a zener diode (or capacitor) which has shorted out.
The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...-
by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
I bought this from an eBay seller but unfortunately they only had one
I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
I bought three of from them to also make battery packs with this output power limit in mind
I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery... -
by unimatrix93Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
The led strips has 9 6V leds.
1 Photo - Loading...
