Power bricks in series?
+ More Options
Latest Activity
  • Curious.George
    replied
    Re: Power bricks in series?
    Originally posted by eccerr0r
    Incidentally, are we "overloading" or actually "underloading" it? (What current is the 5V supply supplying when hooked up in inverse series with a 12V power supply? Where is the energy going? Is this healthy for the PSU?)
    No reply needed, just some food for thought...
    That depends on the design of the power supply.
    If it is only capable of operating in the first quadrant, it simply won't work (in this configuration).
  • eccerr0r
    replied
    replied
    Curious George already answered this, but I am posting simply to confirm that I do this all the time as well - typically with small power adapters of various sizes when I need an odd voltage.
    The other day, for example, I was dealing with some larger-ish NOS 50V capacitors. Before using them, I wanted to reform them. The highest voltage power adapter/brick I have is 34V from some HP printer. I also have a number of 5V, 12V, and 15V power adapters. Taking a 15V brick and putting it in series with the 34V brick provided very close to 49V, actually - just a smidgit under 50V, which was exactly what I wanted.
    As CG mentioned, just watch out if the adapters are grounded. 2-pronged power adapters/bricks are almost always floating/ungrounded, and thus can be connected any which way you like. Adapters with 3-prong plugs are usually grounded (that is, secondary/output ground is tied to primary ground.)
    In terms of "un-grounding" a power supply, the easiest way is usually to take a 2-prong "extension" wall adapter plug and plug the power supply into that. However, if you do that, beware that grounded PSU's often have ceramic Y2-class capacitors from Live to Ground and Neutral to Ground (for extra EMI/RFI suppression.) Leaving ground floating can result in an AC voltage equal to half of your line voltage (about 60V AC for 120V line and 120V AC for 230/240V lines) present on the ground. This voltage is limited to very small currents and will quickly drop even with a tiniest of loads to ground (so it's not dangerous to you... though if the Y2 caps are large enough, sometimes you may feel a slight "tinginess" if you touched a grounded object.) But if you are dealing with audio circuits, beware that this can introduce line hum into your device(s). Then again, grounded SMPS adapters can also pretty bad about leaking line frequency hum into audio devices.
    That aside you can also usually share ground between power adapters/bricks and then use the difference in potential between the positive outputs on each adapter to get a voltage that you don't have. For example, last week I wanted to quickly test some PC fans @ 7V to see how loud they are. I don't have an adapter that outputs 7V. However, I do have a good number of 5V and 12V adapters (and always keep a few out next to my bench, since I don't have an adjustable PSU either.) Connecting the (-) / ground on the 5V and 12V adapters doesn't change their output voltages. However, I can connect the fan's positive (+) terminal to the 12V adapter's (+) terminal and the fan negative (-) terminal to the 5V adapter's positive (+) terminal. The difference is then 12 - 5 = 7V. As long as I don't overload the max current limit on each power adapter, I can safely use this. The same applies to series power adapters (i.e. don't try to pull more current than each adapter is capable of.) In my case, my 12V adapter was rated for 1 Amp and my 5V adapter for 2.5 Amps. But the fans I was testing are rated for 0.4 Amps at 12V. Thus, @7V, they were pulling even less current and not overloading either adapters.
    replied
    Originally posted by Curious.George
    "Either" should be neither cuz you don't know how the load is wired wrt "earth".
    English is my second language.
  • Curious.George
    replied
    Originally posted by budm
    Also make sure that either one of the output of each one of the power supplies is not connected to safety ground.
  • Curious.George
    replied
    Originally posted by evilkitty
    I do not have a variable bench power supply so i was wondering if i can do this
    If i take a DC 12v and a 5v power brick is there any problem putting them in series to get 17v? or using two 12v bricks for 24v
    if i can do this how would i calc the amperage i would need from both bricks
    The load will determine the current (amperage) that will be drawn from EACH power supply (as the load current flows through one power supply, then the other before getting to the load).
    This sort of connection is often possible, but depends on the design of the power supplies and the characteristics of the load (highly reactive loads can be challenging).
    I use a pair of 80A 12VDC power supplies rescued from a server, wired in series, as a "battery eliminator" for my electric wheelchair (big batteries are expensive and "die" if left unused for months at a time; power supplies are always waiting for use!).
    I had to disassemble each to ensure I could isolate "ground" (0VDC) from "chassis" -- which is also connected to "earth". The 0V connection on power supply #1 is tied to "wheelchair 0V" while the 0V from supply #2 is tied to the 12V output of supply #1. If the chassis/earth/ground connections hadn't been severed, the 0V of supply #2 would be "earthed"... as would the 0V of supply #1. So, the 12V of supply #1 would be connected to "0V/earth" at supply #2 -- which would be the same as earth/0V of supply #1 (a direct short).
    Try your setup with a dummy load before you risk it in a "real" use.
    Also, note that you can often tweek the voltage feedback on the power supply to get some (small) range of output voltage adjustment. You have to be careful as this can change the thermal characteristics of the circuit.
  • evilkitty
    replied
    It is, but still a general question
    * the mist thing is at my moms place do i do not have it with me to open it today to check the cap rating
    replied
    https://www.keysight.com/main/editor...0&lc=eng&cc=US
    https://www.acopian.com/acopianPower...lies-in-Series
    replied
    Is this related to this thread? https://www.badcaps.net/forum/showth...932#post971932
    replied
    I would highly recommend you think about buying one and if you decide to buy one I would recommend buying one that has 50 or 60 volt and at a minimum 3 amps with meters for the output this is a nice feature
    You could buy one with lower voltages but when I did this I would another one with higher voltage
    They start with voltages like. 12 / 15 / 30 / 50 / 60 / 120
    This is only an example of the type of power supply I am talking about
    https://www.ebay.com/itm/1PC-KPS605D...8AAOSwljFd5HDc
    replied
    It going to be difficult to do this however you can put a mr16 20 watt light bulb in series with device and have some current limiting which would be better than none
    As far as your other question about putting bricks together for more voltage I have not done it myself so will not comment on how to do it or weather or not it would work or not
    Each brick should be at least an amp
  • evilkitty
    started a topic Power bricks in series?
