Any idea what power adapter this thing uses?
  • evilkitty
    • Nov 2017
    • 299
    Pictures: https://imgur.com/a/KA1J7oy
    Not sure what you call this thing, but what it does is turn water into a cool fog kinda like how LN2 looks when it boils
    The power adapter has been lost for over 10 years, i do not know if this thing uses low voltage AC or DC, guessing it uses at least 9v and at most 18v
    there is no marking on the housing that says what kind of power input it uses
    • Jul 2011
    • 6057
    Re: Any idea what power adapter this thing uses?
    First thing is what is the voltage rating on the capacitor by the power jack
    Second what is the part number of the ic chip by the power supply jack
    Third thing is there a rectifier or a diode near the power jack
    • diif
      • Feb 2014
      • 6978
      • England
      An ultrasonic mister with what look like LEDS around the edge.
      https://www.aliexpress.com/item/4000021665295.html
      They are DC, usually 24v with some of the smaller ones being 12v.
      • evilkitty
        • Nov 2017
        • 299
        Thanks, i have several adapters on hand, just did not know what i needed to wire to the thing to make it work
          I see rectifier by the switch, the cathode is connected to the + of filter cap, so check the Voltage rating of that filter cap.
          What is the P/N of Q3 right next to the dc Jack/filter cap? it may be Voltage regulator IC.
          • evilkitty
            • Nov 2017
            • 299
            Tired 12v dc, it pulled 1.8A and it looked like it was not enough power to fully turn on
            I'll see if i can get that off the pcb later today
              • Jul 2011
              • 6057
              Do you have a adjustable lab power supply
              If so set the amperage for 1.5 ( do this is with the leads shorted together) and slowly adjust the voltage until the device works correctly but be careful doing this but do not go higher than the capacitor rate voltage next to the power supply jack
                So what is the Voltage rating for the filter cap we asked for?
                1.8A @12V seems to be a lot.
                • redwire
                  • 3912
                  I have an older one (without LEDs) box says AC24V 1.3A and I thought it came with a heavy AC adapter with transformer. Newer ones use smaller 24VDC 800mA SMPS adapter. You can search "12 LED mist maker" many say "24VAC/DC" so I don't think it matters.
                  Don't run these without an 1/2" water over the disk or the shutdown stays on.
                  • evilkitty
                    • Nov 2017
                    • 299
                    IC Part Numbers:
                    https://i.imgur.com/86askow.jpg
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      09-06-2024, 05:59 AM
                      HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 02:15 PM
