Decorative Solar Lamp Question
+ More Options
Posts
  • mmartell
    • Oct 2013
    • 3189
    Re: Decorative Solar Lamp Question
    It's meant to sit flush but first things first, need to see if running jumpers make the panels work again.
      • Jul 2011
      • 6031
      Best things to use is component leads work real good this type of repair
      Unless you have battery tabbing wire on hand would be best thing to use
      • mmartell
        • Oct 2013
        • 3189
        Ok repaired two broken traces and I quickly measured over 5v under my led lit magnification lamp. Will try today under proper sunshine to see what the panel puts out.
        I used some really small gauge insulated wire to bridge the traces. I think I will redo that work after a little fact finding with the panel itself now that it's working.
          • Jul 2011
          • 6031
          After you finally fix the breaks seal the repairs with marine epoxy I would also apply some over just the tabbing material only you do not need to make very thick but you need thick enough to seal it so moisture does not continue eat away at it
          • mmartell
            • Oct 2013
            • 3189
            I brought it out into the sun today and registered 6.9v unloaded.
            Next step (after making the repairs permanent) is to decide which electronics to use and what type of battery.
            Is a Li-ion cellphone battery a good choice for this application ?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8694
              I have a solar panel I wish I could repair, would be nice if it's just the interconnect but the tracks on the wafers themselves look oxidized. Should take another look at it, and without the charge controller... (BTW, problem I'm seeing is that it cuts in and out, sometimes generating power but sometimes not, and sometimes hitting the panel makes it work again...)
              Sort of spoiled now with the 100W panels, the bad panel is probably no more than 5W or so if that much -- drop in the bucket compared to trying to get the 100W panels optimized.
                LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
                I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
                Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
                Pictures will come later when I have the lighting fixture gutted and have the battery...
                08-11-2024, 11:10 AM
              • vestaviascott
                Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                by vestaviascott
                Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                Here's what happens:
                1) Power on
                2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                3) Blue status light flashes for appx 4 minutes...
                07-29-2020, 06:08 AM
              • AJ847.63e
                BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                by AJ847.63e
                Hi All.
                Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                09-18-2023, 06:42 PM
              • mikey5791
                Help on Samsung Syncmaster T220 dead ccfl lamp
                by mikey5791
                This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                10-18-2020, 03:17 AM
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
