Need help ID'ing a diode - T2D85
  • ngth82
    • Jul 2015
    • 541
    Hi all -
    I have a TV SMPS with a bad diode.
    The marking around the component body is "T2D85" but i haven't been able to find a datasheet for it.
    The diode is a through hole axial. The body is black. The band and text is a dark red color.
    Edit: I have a replacement part for U101 coming next week from Digi-Key.
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
  • R_J
    • 9607
    Re: Need help ID'ing a diode - T2D85
    What is wrong with the diode? It can be a TVS diode and they can check open. If it is checking shorted in circuit it could be due to the shorted ic
    • ngth82
      • Jul 2015
      • 541
      I removed it to check for shorts in the supply circuit for U101. While i had it out, I noticed that the diode doesn't beep with the meter in diode mode - no forward drop.
      -Thomas
      • redwire
        • 3912
        I find the root part number for T2 diode is ST02D as a Shindengen "trankiller" TVS zener+diode inside. So a T2D85 is 85V ST02D-85 and would test open-circuit unless you can test it past 85V.
        I don't think it's a rectifier diode but would have to see the schematic.
        • ngth82
          • Jul 2015
          • 541
          Thanks for the lead! I'll look into the PN you identified.
          -Thomas
          • petehall347
            • Jan 2015
            • 4440
            • United Kingdom
            check the symbol underneath it
            • R_J
              • 9607
              These type of diodes don't "BEEP", they are usually two internal diodes with common cathode
              • ngth82
                • Jul 2015
                • 541
                Thanks guys. The board symbol for this component is the same as the one immediately south of the red box from the pic in Post #1.
                I just realized that i didn't post the board number information.
                This is a LGIT SMPS board for a Philips TV. Board PCB PN: 2300KEG031A-F
                Funny, Coppell TV Repair also mentions that U101 is a common failure (which this appears to be the case):LINK
                -Thomas
                • redwire
                  • 3912
                  I think OP's could be a ST02D-82 (note datasheet wrong 67V spec). Mouser sells them.
                  It looks like other people mistakenly think these T2D snubber diodes "power clampers" are open-circuit, when they are just HV zener plus diode:
                  looking for T2D80 https://www.badcaps.net/forum/showth...t=20211&page=2
                  Sony Diode T2D98 ST02D-140 https://www.badcaps.net/forum/showth...t=54016&page=2
                  T2D98 https://www.badcaps.net/forum/showthread.php?p=671655
                  T2D40 https://www.badcaps.net/forum/showth...067#post221067
                  • ngth82
                    • Jul 2015
                    • 541
                    Also, looks like this component sits across the two terminals of the transformer that bridges the hot and cold side of the SMPS. I removed the transformer and checked for shorts across the three separate windings. The transformer to be okay.
                    -Thomas
                    • R_J
                      • 9607
                      That TVS (HV zener) diode (D106A) is across the primary, In some cases they use a UF4007 for D106 and have C103 and R102 populated which are in series with the uf4007 fast recover diode.
                      • ngth82
                        • Jul 2015
                        • 541
                        Update: The FSQ510 arrived and was replaced on the SMPS.
                        The TV fires up and appears to work.
                        -Thomas
                        • dennis_elx33
                          NO BODY MARKING Diode
                          by dennis_elx33
                          Hello Everyone,
                          I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                          While compared to the reading of another diode from the next channel it won't read at reverse bias.
                          Now the problem is; it does not have any body marking.
                          So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                          What do you think is this diode?
                          Can you please suggest what part number can i use to replace this faulty diode instead?
                          Hoping that you...
                          06-14-2024, 12:36 AM
                        • asr
                          Finding replacement diode iPad Pro 3rd gen A1701
                          by asr
                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                          07-09-2024, 06:24 PM
                        • unimatrix93
                          TV backlight zener diode
                          by unimatrix93
                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                          The led strips has 9 6V leds.
                          02-10-2025, 12:13 PM
                        • Baste
                          MBR3045CT and SR3045LCT Schottky diode testing help.
                          by Baste
                          Hello experts,
                          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                          Aneng ST182 Meter.
                          Diode mode.
                          MBR3045CT:
                          Diode mode
                          Pin 2-1 - 0.150v
                          Pin 2-3 - 0.150v ...
                          10-21-2025, 06:14 AM
                        • NicRac
                          monowheel repair,Is the diode the problem?
                          by NicRac
                          Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                          First of all, I am new here. Therefore I will shortly introduce myself.
                          I am Nico and currently I study Physics.
                          In my freetime I like to build and repair stuff. Especially big battery's.
                          A few years ago I got myself an electric unicycle, monowheel or however you call that.
                          The battery bms was broken so I replaced and resolder that. Nothing big.
                          I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                          07-26-2024, 06:13 AM
