Cable filters and if anyone has used one before?
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Re: Cable filters and if anyone has used one before?
    All I have to say is that my Son IS the cable guy...LOL No problems or bills here....Lots of channels too.
    Mark Twain
    John Paul Jones
    Rod Serling
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      hmm... i was till seeing traces of nettalk dweeb as far back as google search page 14... damn, it had to be a bot.
      sigpic
      (Insert witty quote here)
      • weirdlookinguy
        • Sep 2007
        • 1638
        lol too funny!
        • fez
          • Oct 2009
          • 11
          "Every so often your cable company sends out a test signal to ensure your cable box is online. Because your digital cable filter prevents your box from sending information BACK to your cable company, your box will no longer be able to report back to your cable provider that it is online. When this happens several times in a row, eventually your cable company will shut off ALL of your digital cable television programming."
          Hi i agree with krankshaft, in england we have cable and although the encryption/decryption is a little different its basically the same. When you use a filter (im not selling) it stops talkback and eventually the CC want to know why the box is not talking back ie what channels you get on ppv, and what you are subscribed to. The only way of free is by Modding the box.
          • NxB
            • Feb 2009
            • 1595
            Modding the box is hard. You have to activate it and change the serial (so they don't deactivate it) . You will still only get the channels you originally paid for.
            • Patch2
              Cable Repair
              by Patch2
              I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
              01-02-2025, 06:04 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • conghuyms
              I need datasheet cable eDP LCD 30 pin slim pls help me!
              by conghuyms
              My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
              08-22-2025, 11:16 AM
            • fweonea
              HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
              by fweonea
              While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
              I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
              01-16-2024, 11:35 AM
            • marce002
              Help me make charger USB C cable with no cc pins!!
              by marce002
              Hi all, please
              I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
              How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
              NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
              here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
              thanks in advance!!
              11-17-2023, 09:16 AM
