Need to design an IR Receive amplification circuit for digital processing
    • 31283
    Re: Need to design an IR Receive amplification circuit for digital processing
    Originally posted by EasyGoing1
    I'm not sure how any of this information is relevant to my original question, which was... how do I design a circuit such that when a voltage hitting the base of a transistor is at 5V, the transistor is off, but when that voltage goes to 4 volts or lower, I need the transistor to be on as hard as it can be?
    you need a schmitt-trigger like a 74hc14, not a transistor.
    but that's not going to help because your reciever output is already digital - you need a better and more sensitive one.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      but that's not going to help because your receiver output is already digital - you need a better and more sensitive one.
      I'm not convinced that it won't help, because when a weak signal reaches the receiver, it sends a higher voltage to the Arduino ... and as I stated when I started this post ... if that pin gets between 2.2 and 2.5 volts, it will waffle the interrupt trigger, so if I can set 4 volts as an absolute that will guarantee sinking that pin to ground, then I will have completely overridden the effects that a weak signal has on this ir sensor and I will have given the Arduino a solid 0 even if the IR receiver gets a weak signal ... (because a strong signal causes the IR receiver to go to about 1 volt while a weak signal can make it only drop to 2-ish volts) ... so then with this idea, all that signal needs to do is drop that voltage by only 1 volt and I'm in business ... make sense?
      sigpic
        You still refuse to give us the spec of the IR receiver you are using and also the waveform, simple request.
        • redwire
          • Dec 2010
          • 3912
          We don't know how OP is measuring the pulse voltages. With a multimeter it's averaged and doesn't tell you much.
          OP is also thinking a weak signal means less signal swing which is not the case with modules because they have built-in amplifiers, AGC, clamps and a comparator to give the same output signal weak or strong IR signal.
          A photo-transistor will give a weak or strong signal though, so this seems part of the confusion or maybe even what OP is using for a receiver. We will never know.
            Yep, we will never know. OP asks questions but refuse to provide the info + lack of basic understanding of the electronics and devices.
            • truclacicr
              • Apr 2019
              • 353
              • australia
              #26
              Use a single supply, rail to rail comparator, eg MAX941.
              https://cdn.badcaps-static.com/pdfs/...acaf490fe5.pdf
              Use a resistive potential divider for the 4V set point (see figure 6 on page 9).
              • u666sa
                HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                by u666sa
                Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                Platform: ipa32 la-m024p rev 1b
                Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                I found a short on the other side:
                10-04-2025, 05:03 PM
              • MisterAIL
                PS5 digital / No Power / No Beep / Good power supply
                by MisterAIL
                Brought a non functionnal PS5. Apparently only a bad PSU...
                No beep, nothing.
                After some tests i found this :
                - PSU is fine (12 volts stable)
                - 12 volts line is shorted
                - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                - By the way, nothing change. No signal, no power, no beep.
                Mesuring all rails with my workbench psu (12 volts input)
                - 0.00 amp drawing
                - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                03-12-2024, 03:24 PM
              • Mark R
                The Overseas Only Kenwood Model KR 790
                by Mark R
                I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                09-23-2025, 08:27 PM
              • Astonished
                Fixing the Charge Circuit of the Batteries of the DC Motor
                by Astonished
                Hi friends of electronics
                What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                Please help me fix this circuit.
                (the datasheet of the IC: https://pdf.datasheet.live/28...
                01-28-2025, 06:24 AM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
