Shredder very slow to start
  • jinu_j
    • Feb 2016
    • 90
    • India
    Re: Shredder very slow to start
    Voltage across C1 is 3.31 V.
    The violet and grey are from the Photodiode (Paper detection sensor). Marked as C and D in the last image. The voltage across them is 2.25V
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      What's the voltage at the anode of D6 when a sheet of paper is inserted?
      Ah now we're getting more critical information. Too many wires going everywhere, no idea where they go...
      2.5 volts across the phototransistor is fairly low when paper is inserted IMHO, though it should be just barely enough.
      • jinu_j
        • Feb 2016
        • 90
        • India
        voltage at the anode of D6 = 2.23V. Most of the wires are going to the motor. The key wires are the ones going to the IR transmitter marked as A and B and the ones coming from the IR receiver (photodiode) marked as C and D
        • R_J
          • 9540
          The voltage across C1 is too low, Check R3, R11 & R10. ZD1 will set the voltage across C1, What is the number on ZD1
          • jinu_j
            • Feb 2016
            • 90
            • India
            R3 is 48 Ohms. R11 and R10 are 380KOhms. ZD1 is 4742A
            • R_J
              • 9540
              ZD1 is a 12volt zener, You should have 12 volts across C1. That yellow capacitor across R11/R10 could be open.
              Check the a/c voltage between ground/neutral and each side of that yellow cap
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                if D3, D4 are good, as well as ZD1, I hope it's not that yellow capacitor next to R3...
                • jinu_j
                  • Feb 2016
                  • 90
                  • India
                  #28
                  Thats a X2 104k 275v Capacitor.
                  • jinu_j
                    • Feb 2016
                    • 90
                    • India
                    #29
                    Its 249V on one side and 2.25 V on the other side of the yellow capacitor
                    • R_J
                      • 9540
                      I suspect the cap is open.
                      That cap is used to couple the a/c to the diodes, if it is bad/open, you will not get enough a/c voltage to get the 12v needed to operate the circuit. the only a/c getting to the diodes will be through the two 470k resistors. thats is why you only get a couple volts across C1
                      2.25v a/c feeding the diodes would result in only about 3vdc across C1
                      • jinu_j
                        • Feb 2016
                        • 90
                        • India
                        #31
                        Ok will replace this cap and then update. Thanks a lot for your help so far.
                        • R_J
                          • 9540
                          If the other yellow cap is the same or close to the same value, you could swap them to see if the 12 volts comes up. That other yellow cap is for suppling the 24 volts to the relay, so if you do swap the caps you would not get the 24 volts for the relay but should get the 12 volts across C1 This would confirm the cap is bad and the zener etc. are ok.
                          I would replace both caps if one is bad.
                          • jinu_j
                            • Feb 2016
                            • 90
                            • India
                            #33
                            can i replace the the X2 104 K capacitor with X2 224 K as i have that in stock, the 104 I will have to order
                            • R_J
                              • 9540
                              I think in this situation it would be ok to use the higher capacity cap, it is not that critcal a circuit for the capacity of the cap as long as the voltage is high enough
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                IMHO it's ok to use the 224 temporarily as a test though long term it may not be a good idea. Make sure the diodes are good before buying anything, though the capacitor seems most suspicious.
                                • jinu_j
                                  • Feb 2016
                                  • 90
                                  • India
                                  #36
                                  Good news. Replacing the capacitor solved the problem. Now shredder is back to full function. I checked the 224 and found that even though it says 224 the actual capacitance was only 104nf. So i guess that is also on its way of failing. So ordered new capacitors to replace both the AC caps.
                                    Originally posted by jinu_j
                                    Thanks. This is a new shredder and not used much so no issue with gears. I have ordered the replacement CAPS. will replace those and update once done. Thanks folks
                                    That is pretty bad to have new unit with failed dropper cap already.
                                    • juergenb
                                      Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                      by juergenb
                                      i am asking for some Help.
                                      I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                      The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                      So i got a few of these from Banggood.
                                      I swapped the motor and now i have a new fault condition.
                                      In a working Frother you would press the start button, it will light red and work for a few minutes.
                                      If you press longer it will light blue and just mixup the milk.
                                      With the new Motor it just starts...
                                      03-23-2021, 11:24 AM
                                    • sbt123
                                      charnwood w821 mini wood lathe motor problem
                                      by sbt123
                                      hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                      10-27-2024, 03:43 AM
                                    • Per Hansson
                                      Motor run capacitor physical size vs voltage rating & measurements?
                                      by Per Hansson
                                      (TL;DR skip the first paragraph)
                                      I encountered my first dead motor run capacitor at a customer this week.
                                      For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                      (Unless a servo motor makes more sense that is).
                                      But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                      The pump would run but sometimes trip the 10A breaker.
                                      I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                      Then it could...
                                      09-20-2020, 06:32 AM
                                    • mikey5791
                                      Help identify this motor
                                      by mikey5791
                                      Hi all forum members,
                                      Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                      Correct me if i am wrong on the initial test.
                                      Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                      11-24-2023, 07:54 PM
                                    • gjlpereira
                                      MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
                                      by gjlpereira
                                      Hi forum.
                                      I'm working on a macbook pro, model a1708, that is running extremely slow.
                                      Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
                                      One other symptom of the problem with the machine is that the fan is always running at full speed.
                                      This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
                                      09-06-2022, 07:45 PM
