One 120V grid tie inverter on 240V split phase system?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    First off I'm not sure if the 120VAC grid tie inverters are all NEC/UL certified.
    That being said, what happens if you use one of these if you do have split phase 240V like most of NA, and only have one inverter on one of the two phases?
    I can only think of weird stuff happening, none of it is good, so what about those off the boat 120VAC GTI's?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: One 120V grid tie inverter on 240V split phase system?
    If you do not sync the inverters output waveform to the incoming mains it will sink a metric shitton of power and result in smoke
    Follow the white rabbit.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Sync is not going to be a problem - that's what GTI's were designed to deal with. I specifically wonder about half a split phase operation which is undefined for me...
        • 31199
        well your power meter wont be happy!!!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I have one of those big brother power meters that theoretically support 240V GTIs and actually has two arrows - one to each possible pointing direction that power can flow.
          But who cares what the power meter says as long as it's less than what it would normally would have measured, I generated my own power, the grid doesn't have to supply me as much power!
          So nobody tried yet? Someone has to have tried...or perhaps I'm overthinking the possible issues?
          I never liked the middle tied neutral thing... gives me the jeevies thinking about current imbalances, which is exasperated by a half phase GTI -- though is it any worse than unplugging everything on that phase...
          (Then the other question is: which is better, two half phase GTIs on each phase, or one big 240V GTI that drives only the two phases and ignores neutral...?)
            • Jul 2011
            • 6065
            Originally posted by eccerr0r
            (Then the other question is: GTI that drives only the two phases and ignores neutral...?)
            I could think about a lot of items that would not be happy about this if the phasing is not right and would you electrical feed be unbalanced in that situation
            But a better question is why would want to do this way
            I agree with you that I would not want to use a single 240 volt unit but I would go with two 120 volt unit instead
            Because would a 240 volt unit work if one phase has more of a load on it than the other and does the 240 volt unit have a neutral wire on it
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              But effectively the power company is doing exactly this to you when you get one phase 240V - they don't ship neutral to you...
              However for a GTI there probably should be a "neutral" point of sorts...well, at least if you implement it a certain way...
                • Jul 2011
                • 6065
                You are right to a point in that the neutral is more or less an earth ground at utilitie the pole for 120 volts on each side
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  So if you have a 240V GTI, that's got no ground reference in the circuit other than the case that's isolated from the 240V, where do one connect the GND?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Yes the whole intent of having half split phase GTI is purely cost, especially if the intent was not to sell back but rather compensate ones own use on that particular leg.
                    But now... after thinking about this some more, the neutral tie is key.
                    if the neutral tie is perfect, a half split phase GTI should actually work and nobody would know the difference. Mostly.
                    However if the neutral tie is compromised, all of the problems I've thought about become real issues, among a whole slew of other problems that would show up even without a GTI.
                      Should I take this undertaking “ Fault & Not Work 8000W LF Split Phase Pure Sine Wave Power Inverter DC24V/AC110V”
                      Is it worth the time to investigate what is wrong with this inverter according to the seller they offer repair parts I asked them what parts do they offer as repair parts cost $159.00 free shipping...
                      06-12-2025, 06:46 AM
                    • eccerr0r
                      A modified sine wave inverter + a grid tie inverter?
                      by eccerr0r
                      If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                      Next thing is trying to charge the batteries using solar power, but that's another issue ...
                      08-31-2023, 09:14 PM
                    • x_orange90_x
                      Vizio E55-E1 bad backlights or bad inverter?
                      by x_orange90_x
                      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                      I don't know how exactly to test the inverter itself. Is it...
                      01-29-2025, 09:24 PM
                    • Gentian
                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                      by Gentian
                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                      03-06-2023, 07:07 AM
                    • valvashon
                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                      by valvashon
                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                      01-04-2024, 01:44 PM
