CAP- esr value?
  • bogart219
    • May 2009
    • 176
    • usa
    CAP- esr value?
    Hello again,
    I'm using my dick smith ESR meter to measure a cap. Measured out of circuit. Its a 200volt, 470 u ohm electroylitc. I measure .99 on the meter.
    The chart of the front says this:
    at 100volts = .05
    at 250volts = .3
    I'm sort of in between with 200volts. What would you say would be the worst case esr for this cap? Thanks!
  • s0lid
    • Jul 2009
    • 14
    Re: CAP- esr value?
    200V should be .2ish.
    Same s0lid from XS and 2cpu forums.
    • bogart219
      • May 2009
      • 176
      • usa
      Re: CAP- esr value?
      • Huckfinn
        • Jan 2009
        • 43
        Re: CAP- esr value?
        sOlid is right. A good 470 @ 200volts should read between .1 to .2 , but at .99 , that cap is on the way out.
        Huck
        • chth96
          by chth96
          03-09-2024, 10:03 PM
          12-31-2023, 06:04 AM
        • jorpec
          by jorpec
          Hi
          Thnaks
          01-23-2023, 10:37 AM
          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
          12-14-2023, 07:45 PM
        • Stephan Mathers
          EDMI ATLAS MK10 Electronic Meter Discussion
          by Stephan Mathers
          Greetings, new guy here but always interested in the crazy universe of modding
          We just finished construction of around 25 vacation houses, all inside the same private area.
          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
          05-20-2025, 09:09 AM
