Is this a FAKE MosFET 2SJ78?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    This is the second time I came across this situation when repairing Amplifiers
    I Have this InterM amp and someone has worked on it before by another repair shop who couldn't fix it. I replaced a couple of short circuit output devices and found I still had a problem with one bank of output transistors on one channel being hard on when the amp is powered up.
    Fortunately the light bulb limiter i was using saved any more damage being done
    I traced the problem to a 2SJ78 MosFET that drives the output, it had been replaced already with a 2SJ200 'equivalent' device but I quickly spotted from the datasheet that this 'equivalent' has the Source and Drain pins transposed.
    So I ordered a 2SJ78 from ebay and fitted that. I found I still had had exactly the same problem with one output bank on that channel being hard on so I unsoldered the replacement and checked it for polarity
    Once again I have Drain and Source wrong way round!!
    Here is the datasheet
    http://pdf1.alldatasheet.com/datashe...CHI/2SJ78.html
    1-Gate
    2-Source
    3-Drain
    From the attached photos you can see my Atlas DCA55 shows the 2SJ78 I bought...
    1 - Gate
    2 - Drain
    3 - Source
    I then wondered if the datasheet was wrong so I tested the same device from the working channel and that pinout matched the datasheet.
    As I said this is the second time i have found a power MosFET with reversed Source and Drain pins. The first time it caused a lot of head scratching before I fixed the amp (I actually soldered short wires to the device pins and crossed them over to the correct pads on the PCB and that did the trick)
    It's only because I came across this exact problem before that I found out what is going on quite quickly this time. Still IMHO it's hard enough to diagnose and fix these amplifiers without this sort of additional headache!
    So what's going on here? Is it a fake I have been sold? Has the official pinout of this device been changed at some time over the years since this amp was manufactured?
    Anyone else ever had the same problem, is it commonplace?
    Rich
    Last edited by dicky96; 04-29-2019, 05:35 AM. Reason: corrected mistake in pinout description
    Follow me on YouTube
    Learn Electronics Repair
    Re: Is this a FAKE MosFET 2SJ78?
    Look at the print on the body of the original and the new one you bought, you may be able to tell that the one you bought is not the real part. Does the original have Green body?
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      TBH budm - I just did what I did last time I came across this same issue with a replacement MosFET - I bent the outer Pins on the device to fit into the left and centre hole in the PCB, then soldered a short wire from the (cut short) center pin, applied a bit of heatshrink so it could not short the other pins and soldered the device with the Source and Drain reversed.
      That fixed the problem with one output bank on Channel 2 being hard on, and the amp now works just fine (apart from now i spotted one of the cooling fans isn't running - sodding typical!)
      So I was right, same as last time I had a similar problem. The replacement from ebay is electrically an equivalent but physically it isn't.
      OK I'll freely admit there is a certain amount of kudos in fixing these sort of stupid faults another repair shop either couldn't fix, or worse still even caused.... but I would prefer not to have the hassle TBH
      Funny enough the same customer has just brought me another Amp that another repair shop can't fix......... hmmm
        • 31012
        most chinese stuff is manufacturing surplus,
        the part could be original but part of a special order.
        a lot of companys use custom parts with pins switched or in the case of memory devices, custom i.d. codes.
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • dj8452000
          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
          by dj8452000
          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
          02-18-2025, 08:28 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • davidebeatrici
          Sony M851 MBX-217 no POST and restart loop
          by davidebeatrici
          Before proceeding with a component level repair, the usual troubleshooting process was followed:
          1. Disassemble and unplug everything except the power connector.
          2. Replace RAM.
          3. Replace CPU.
          4. Rewrite BIOS.
          Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
          After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
          I thought to myself "Well,...
          07-03-2025, 04:19 PM
